FilaToon / Cell shaded rendering with Filament
11920212325
  • vrba79vrba79 Posts: 1,483
    TheNathanParable said:
    Ok, so...I can't show the full version of this as it's intended for my uh *ahem* alternate BlueSky account... devil
    But I REALLY like how the face came out, so i'm sharing that here. @Oso3D 's FilaToon Kit was especially useful here, as well as his FilaToon Beards.
    https://www.daz3d.com/oso-filatoon-kit-for-genesis-9
    https://www.daz3d.com/oso-filatoon-beards-for-genesis-9
    Wow! We're pushing past the anime-style implications of this shader.
  • 3Diva said:
    @captainalvord Nice! He reminds me, slightly, of Christopher Walken.
    I noticed that too after I posted it.  Wasn't my intention but a nice surprise.
  • cain-xcain-x Posts: 208
    edited February 5
    Just wanted to verify all the testing and work done since Filatoon has been released and the new work put into Filament:
    - Transparency/Opacity still has issues displaying correctly in filament (i.e. hair)
    - Emissives does not cast light to any nearby objects
    - Environment map only works with hdri images, unlike how Iray behaves
    - Reflections only work with hdri and no 3d objects
    Is there some limitation with the Google Filament engine or has it not yet been plumbed into DAZ? Some understanding of the road map will be very helpful as I do have some projects that may require these features or if I need to move this to a render engine that can support this.
    Post edited by cain-x on
  • Richard HaseltineRichard Haseltine Posts: 108,205
    While both Filament and Iray offfer a form of PBR rendering they are not the same. Filament and Iray do have documentation, and the DS chnage logs etc. tell you which versions DS is using, if you wish to compare features.
  • 3Diva3Diva Posts: 11,974
    The transparency/opacity issues have been solved if you use the Filatoon Shader on the hair (or anything else that has a transparency/cutout opacity map).
    You can do a lot with the eyes if you expand the limits.  Also, just a tip but any of the (very) old 3Dream and Mairy hairs work great as toon hairs, and they have a LOT of morph options.  Just another render, testing eye shapes and using some old stuff!
  • ArtiniArtini Posts: 10,323
    edited February 8
    Experiment with https://www.daz3d.com/atmosphere-for-filament
    Only Mist Plane looks ok, Atmo props takes away the shadows.
    Also used https://www.daz3d.com/nutcracker-pro
    805 x 1200 - 247K
    Post edited by Artini on
    Was there any doubt that 3DO would take to this like a fish to water?
    The 3Dream and Mairy hairs are some of my favorite hairs! They actually look really good in Iray too. And, as you pointed out, they come with so many style morphs. It's awesome, and almost like buying multiple hair with the one. I've been trying to get them all. I bought quite a few but they rarely go on sale since I don't think either of them are making new products anymore. There are still 17 Mairy hairs here in the Daz3D store that I want to get. And quite a few more at Rendo. Such great hair, I don't know if they are still around but I'd love to see them making hair again if they still are.
    I really like the render by the way! I'm not one for "skimp wear" but the art style came out cool!
  • barbultbarbult Posts: 26,257
    edited February 10
    A long time ago, I converted Hal from G8 to G9. Here I added his morph to Base Anime Masculine. Richard Haseltine is wearing his new Fabiana gold chain collar and tag, in case he gets lost again and needs someone to help him find his way home.
    2000 x 2600 - 6M
    Post edited by barbult on
    I've run numerous tests on this - it does not work in all situations. This is especially true if the surface can be see from the back side and the mesh with opacity maps overlaps - depending on the camera angle. This issue still persists.
    While I appreciate the tips, Richard - not knowing when things will be resolved or if they will be supported in the future is difficult in certain projects that have deadlines and goals to meet within a timeline. I can't take the risk in investing hundreds of dollars of assets and tools but come to realize it will not work because of a limitation. Thanks.
    Just testing some things out (1) does the figure work without Filatoon, and I was suprised, you delete that G9 outline and it renders well....and (2) how quick can I convert an old scene with Sakura to toon, and how does it look?  Took about 5-ish minutes, lets call it ten (before and after posted, in both background is postwork).  The inner mouth needed work, but it was just a test.
    edited February 11
    When using Filatoon shader on trans-mapped hair you need to adjust the "PBR Masked Threshold" (it's under the Cutout Opacity channel in the Surfaces Tab):
    240 x 106 - 7K
    Post edited by 3Diva on
  • I was told to adjust that to 0.12. Does 0.24 make a difference?
    This trick also works for foliage.
    It depends on the transparency map. You need to just adjust it to see what looks the best.
    edited February 12
    Thanks - I have tested this before and it does get it about 80% of the way there - it works in certain situations but not for the projects I'll be working on. For some of the hair, it does leave parts of the strands disjointed if the OP maps has some thin faded lines - raising the threashold just makes the hair clumpy. Appreciate the tips.
    edited February 12
    It looks to me, that some hair better converts to FilaToon than the others, like this one:
    https://www.daz3d.com/fn-pixie-hair-for-genesis-9
    so it is a matter of find such ones.
    1920 x 1200 - 382K
    1920 x 1200 - 471K
    Hairs for older figures do seem to work much better. Toon generations hair for instance
  • scorpioscorpio Posts: 8,533
    edited February 12
    Tried a black and white approach
    707 x 1000 - 73K
    Post edited by scorpio on
  • wolf359wolf359 Posts: 3,934
    edited February 13
     I think someone said above, but the Matcaps are just for faux reflections, i don't think they do anything else.
    Matcaps in the common vernacular of 3D/ CG programs do far more than Faux reflections.
    They are typically used to show modeling & sculpting surface details in the viewport without needing to
    even have lights with shadows.
    However they can also be used as an actual  render style
    ( in Blender at least)
    Here is a  Global Graphic Novel NPR style I  amusing in Blender with zero editing of shader nodes, just the default Daz texture maps and the global matcap previews in the Blender viewport.
    No cumbersome  geoshells involvedangry Just import the Daz  content via the Diffeo plugin or Daz to Blender
    instant realtime viewport renders in Blender and a “cartoon” line pass in Adobe After Affects.
     I will be using this toon matcap for my next graphic novel.
    (Free on GUMROAD not Mine!!)
    https://eyedesyn.gumroad.com/l/mgeiu
    Honestly I am not seeing anything in these Daz "filatoon "renders that cannot already be achieved with a  post filter in the FREE gimp krita or photoshop or affinity photo
    and gimp has FREE batch processing script for toon filtering animation frames.
    The Comiclife page layout book design software $30 has built in cartooning filters as well.
    No content restrictions, ALL genesis generations and legacy prop content.
    And easily comping in  of AI generated backgrounds like below.
    of course, your milage may vary.
    1275 x 1650 - 1M
    1275 x 1650 - 2M
    1275 x 1650 - 3M
    1136 x 636 - 740K
    Post edited by wolf359 on
    Filatoon is low resource use, instant results. No postwork can beat that speed.
    edited February 15
    I have to agree with @wolf359 that a little postwork can help.
    I have just applied a Toon filter from the Gimp to FilaToon render and I like the results.
    1920 x 1200 - 1M
  • I combine filatoon with a photoshop actions and I like the results
    1275 x 1650 - 2M
    edited February 17
    I bought Technophilia Retro - Gynoids V3 - Rock-It for 47 cents during one of the sales, because I thought it would look cute in Filatoon. It is a Poser product and I used some Iray shaders and then converted to FilaToon with the V3D FilaToon Converter, Manager and Tools (a very helpful product!). I used the Filatoon Skies. The suit and helmet come from Sci-Fi Retro Space Suit for Genesis 8 Male(s) (autofitted). I boosted the contrast in Photoshop.
    2600 x 2000 - 2M
  • SapphireBlueSapphireBlue Posts: 1,373
    Trying to do a quick catch up. Very cool renders and styles!
    Fantastic work from 3dOutlaw
    Barbult, that last render is super cute and well done!
    There is a new https://www.daz3d.com/1-click-anime
    Just wonder, how well it manages the eyes with different expressions and poses of the body.
    Could be usefull for FilaToon renders.
    Pretty cool idea! Kinda reminds me of Toonify.
  • What was the name of the Toonify product? I tried searching for it and came up empty.
  • MoogeeMoogee Posts: 72
    edited February 19
    I think the product you're thinking of is Cartoonized for both G8 & G9. The down side with it is, if you mix it with the Base Anime shape, you can only dial in the morph so far before the eyes start to pop out. 1 Click Anime seems to address that particulate issue. It'd be nice if there was a G8 version if this.
    Post edited by Moogee on
