Filament Renders
2»
  • faisanfaisan Posts: 600
    3Diva said:
    taiuri said:
    barbult said:
    A Filament render will be exactly what is shown in the Filament viewport. Remember, to render Filament, the selected render engine is Viewport. There is no separate plugin or enhanced features.
    Does this apply for FilaToon too?
    FilaToon is a shader type and uses Filament as the render engine - so yes, as long as you're using the Filament draw option and select "viewport" as the "Engine" you'll render exactly what you see in the viewport.
    To render "Filatoon" you have to apply the Filatoon shader presets to the character and scene elements.
    I also highly recommend using the Filatoon Environment options:
    Oh! I see. Thank you, I had a lot of doubts about this Filatoon. Just a last question: the Filatoon shaders presets are free or are they commercial, or where do I get them?
    All the ones that are really necessary and more are included for free in the updated Daz Studio. They were really generous with them really. You can purchase more in the store, just do a search for FilaToon.
  • 3Diva3Diva Posts: 11,998
    The base Filatoon Shader Presets and Environment settings are free. You'll need to install and update the Genesis 9 Starter Essentials and the Genesis 9 Starter Essentials Expansion. I believe there's also another that needs to be downloaded and/or updated but I can't recall what it is off the top of my head. You can read up more about Filatoon on these two threads:
    https://www.daz3d.com/forums/discussion/704951/anime-toons-and-filatoon-shader-q-a/p1
    https://www.daz3d.com/forums/discussion/704931/filatoon-cell-shaded-rendering-with-filament/p1
    Ok! Thank you so much for the information!
  • mindsongmindsong Posts: 1,743
    edited January 2025
    Do I recall correctly that the DAZ Default Resources package needs to be updated as well?
    And I believe the FilaToon capability was added to the existing filament render engine (along with the mentioned shaders/settings) in DAZ Studio 4.23.0.1 (the most recent Public Release). It's a very recent update feature.
    cheers,
    --ms
    Post edited by mindsong on
    cheers,
    --ms
    Yes
  • vrba79vrba79 Posts: 1,515
    I used to see Filament as a joke. Not any more.
