The Ant Farm's Airdrop Bot
I recently purchased the Airdrop Bot from the vendor The Antfarm  I downloaded and installed it from the Install Manager. When I try to open the figure, I get the message that these files are missing.
/data/TheAntFarm/ADB/AirDrop Bot/AirDrop Bot.dsf
/data/TheAntFarm/ADB/AirDrop Bot/UV Sets/TheAntFarm/Base/default.dsf
The figure appears but it's just big grey boxes. I unintalled then reinstalled it and recieved the same message. I then downloaded and installed it manually. I'm getting the same messages. Any idea how I can fix this?
  • felisfelis Posts: 6,585
    edited January 2025
    If you look in DIM and click show installed files, is the list then fully blue (installed).
    And if you look in your content library does the path that it is installed in then be the same as DS is looking?
    And what is the full error text from the log?
    Post edited by felis on
  • crosswindcrosswind Posts: 10,343
    Sub-folder of AirDrop Bot has a "space character" in data folder. Delete it. Then fill a ticket.
    1938 x 1110 - 183K
  • Ok. Thank you both very much.
  • AntManAntMan Posts: 2,181
    So Sorry for any problems here, of course it's a mistake on my part and Daz and I are correcting the issue. Thank you Crosswind for posting the fix here. I owe you one. As always Daz and I are always looking to deliver the best possible experience and I apologies for this error.
    Thank you everyone,
    John AKA AntMan
    Thank you everyone,
    John AKA AntMan
    Thank you very much ! yeslaugh
