Edge Around Viewport
dash2128
I should remember how to do this, but...in the attachment, notice the grey edges? I downloaded an image color- a shade of grey, into environments- but it did not fit the entire screen. Instead, the default grey still surrounds the borders. Thought I knew how to fix that, but seem to have forgotton. how do I eliminate the default edges, and allow the entire downloaded color/image to fill the viewport again?
In Render Settings>Editor tab you need to set the Dimension Preset to Active Viewport - just remember that your image size will then vary as your Viewport size does.
Thank you!! (Just noticed your reply.)
