Edge Around Viewport
I should remember how to do this, but...in the attachment, notice the grey edges?  I downloaded an image color- a shade of grey, into environments- but it did not fit the entire screen.  Instead, the default grey still surrounds the borders.  Thought I knew how to fix that, but seem to have forgotton.  how do I eliminate the default edges, and allow the entire downloaded color/image to fill the viewport again?
558 x 873 - 25K
  • In Render Settings>Editor tab you need to set the Dimension Preset to Active Viewport - just remember that your image size will then vary as your Viewport size does.
  • dash2128dash2128 Posts: 736
    Thank you!!   (Just noticed your reply.)
