GENERAL FREEBIE REQUESTS Part 2
14344464849100
  • DollyGirlDollyGirl Posts: 2,709
    This one should be fairly easy (I hope) - I'm trying to match hair similar to Zoe from Firefly.
    Here is a list of  hair styles that might work for you. I would recommend that you upload multiply copies of the hair and shift it just slightly to give a more lush look. I have seen this done in a render and it looks really good. All of these were designed for V3. Maria has a couple more hair styles but they are more wavey then curly. Her gallery is  http://www.sharecg.com/pf/full_uploads.php?pf_user_name=mairy&division_id=0&s=dd&pn=1
    Links to curly hair
    Conforming Pregipessa hair by maria http://www.sharecg.com/v/4328/browse/11/Poser/Conforming-Pregipessa-hair
    Curly On The Side by Maria http://www.sharecg.com/v/2963/gallery/11/Poser/katsaro3-CurlyOnTheSide
    Katsaro Hair - Curly Tails Posable Hair by Maria http://www.sharecg.com/v/3878/gallery/11/Poser/katsaro-curly-tails-hair-for-poser-
    katsaro2 thicker curly hair by Maria http://www.sharecg.com/v/2814/gallery/11/Poser/katsaro2-thicker-curly-hair-
    Neraida Fairy Hair by maria http://www.sharecg.com/v/3583/gallery/11/Poser/Neraida-fairy-hair-for-poser-
    Katsaro extensions by maria http://www.sharecg.com/v/2964/gallery/11/Poser/katsaro-extensions
  • fleetppfleetpp Posts: 199
    Anyone know where I can get Chohole's Xmas texture for the M4 Regency outfit (Cho_Xmas_Regency.zip)?  The link on page 9 of http://chohole.ovbi.org/ gives me a 404 error.
    She may see this, but why not send her a PM?
    edited September 2015
    I will ask my site host if he can understand what has happened here.
    Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 110,051
    Moved the hair request from the Free Hair thread to this thread.
    Thank you. smiley
    Here's attempt #2 for the gryphon ring.
    And here's a Luxrender render...
    640 x 640 - 589K
    640 x 640 - 330K
    Post edited by mjc1016 on
  • Very cool mcj.  Considering the people who wear those rings can charge them with magic, yes you don't want to get hit by them.
    This is starting to get out of hand...there's a necklace to finish...and I'll probably post them tomorrow night.
    640 x 640 - 466K
  • Banging my head against a wall here. I created a character morph for Genesis, Red Planet Arachnid, https://www.renderosity.com/mod/freestuff/ziggy-red-planet-arachnid-morph-for-genesis/75406 , and just now discovered that somehow the tongue got crinkled.
    I seem to be unable to restore the tongue to its default with my limited capabilities, so could someone who is handier at modeling apps please help me in restoring the tongue [and only the tongue] back to default Genesis so I can update this morph? It should be a quick fix if you know what you're doing, which I obviously don't, and I would be very, very grateful.
    Please PM me if you can help! Credit will be given, of course...
    --MW
  • Hmm.  Any ideas for Italian / Greek skin tones?
    You might want to be specific to which UVs (V4, M4, Genesis 2 M/F)  you can use.  And do you need male or female?
    It's for two female characters. I've got G2F, A6, V6, and O6 as my preferences.  If need be I also have G1, G3F, and V4.2
    why not add an off-white diffuse color with a pinkish/olive hue  to an existing skin texture?
    And for the record, when I was in Italy there were some natives who's skin tone defied the very existence of melanin.
  • Does anyone know of a way to take a gen 4 (v4/m4) model with a group of morphs and export all those different morphs into one morph so if I click a pose preset it does not over-ride all the other morphs. Locking the morphs seems to only allow the change and lock the value to prevent me from changing it back, and if I save and reload the scene I often need to go back and reinject the morphs to activate the shape changes I made to the figure in before I saved.
    I'm still getting the file not found error. Can you upload it someplace else?
    My site host is very busy at the mo, doing other things, he will get round to it in time.  I am not even sure if I have a back up of those files, would have to check.  He carries a dvd backup
  • Yes there is a way, StratDragon.  It's not the point of this thread so I'll send you a msg.
    I wanted one thats free, I've asked in commons and studio and got no replies. Secondly if you sent me a msg my box is empty.
  • Here is the msg I sent you. Its a process not a product =) There is a way to make a bunch of morphs into one. First, make sure your figure is on Base Resoution, not High Resolution. It's found in General. Next, dail up your morphs, then export your figure as .obj with the Daz Studio settings. It's best if you call it what you want your morph to be called. Delete your figure and load it up again. Select it and load up morph loader pro in the edit -> figure -> Morph Loader Pro menu. hit choose morph files, choose your obj file and hit accept. Your morph should be found in the catagory Morph Loader. Make sure to save it with the Save As function. As a warning, I've only done this with Genesis characters but it should work with v4/m4 the same way. I hope this helps.
  • Stuff I can't find in the shop, so some enterprising designer could make and sell them...er..list
    Decent modern combat pilot helmet / attack helecopter gunner helmet.
    Mine shaft walls / connectables
    Modern Freeway connectables with overpass parts
    Japanese road sign collection
    Japanese lighted billboard collection
    Human body parts - chunky stuff --wow looks, entrails just flew by (don't ask why)
    Destroyed chunks of high tech equipment.
    flying dirt / rocks / stone / brick like a artilery shell hits a wall...the stuff the flies on impact.
    Big city seawall. for port towns
    glass skyscrapers
    I am not suggesting that this stuff needs to be made for free (but you can if that is your thing)
    This is just stuff I could not find for DAZ/Poser  some can be found in PS, but that is after processing..we are talking live objects.
  • opsey, forgot another one
    Kendo armor - as in the sport and the bambo swords they use
  • XaatXuunXaatXuun Posts: 874
    glass skyscrapers
    would this helmet work for you M4 Air Crew Set
    there are a few citys out there, this one sez it has rubble The Ruined City
    here was the search for debris
    Post edited by XaatXuun on
  • Helmet works for fighter pilot, thxs :-)
    debris - looking for objects, not PS brushes. Will likely make myself
  • HellwolveHellwolve Posts: 176
    I'm looking for a hood for V3 (with or without cloak), ideally like the one found with Shukky's God Of Death for A3. Alternatively, I'll gladly hear of a way to make that hood work with V3 without it tearing wink
    Post edited by Hellwolve on
  • Here is such a hood for Genesis, I don't know about taking things back to V3.  http://www.sharecg.com/v/80552/browse/21/DAZ-Studio/Sand-Rider-Outfit-for-Genesis
    You might also try http://laticis.deviantart.com/art/Laticis-Imagery-FREE-G2-Female-Head-Cloth-538078044 as it should drape well on any head.
  • CherubitCherubit Posts: 995
    Hello! :) I need nice characters for female genesis and G2F, with beautiful skin and if it comes with a morph it won't be bad at all! Anybody knows some? I only have Larissa for G2F...
    Post edited by Cherubit on
  • I don't know about G2F skins, but I know Genesis will use V4 skins without problem, and there are plenty of freebie V4 characters that come with skin textures out there. Those are all I really use on my female characters.
  • Hello! :) I need nice characters for female genesis and G2F, with beautiful skin and if it comes with a morph it won't be bad at all! Anybody knows some? I only have Larissa for G2F...
    A good place to find good G2F characters are issues of DS Creative.  I can't tell you which issues, but you can find them on  http://www.daz3d.com/forums/discussion/42372/ds-creative-the-magazine-for-daz-studio-users ;
  • KeryaKerya Posts: 10,943
    IF you have the V4 for Genesis2Female, you can apply V4 characters.
    Else
    http://www.sharecg.com/v/77980/
    http://www.sharecg.com/v/72057/
