Buggy shadow line artifact on hair
I have a strange line on hair. Does anyone know how to fix this? Hairstyle is "Sleek Ponytail Hair for Genesis 3 and 8 Females" by "outoftouch".
  • crosswindcrosswind Posts: 10,139
    edited December 2024
    You cranked up the value in Cutout Opacity on Cap surface of the hair ? Go to Surfaces pane, select Cap surface and check Cutout Opacity. Reset it to 1.0.
    2014 x 1288 - 3M
    2015 x 1290 - 3M
    Post edited by crosswind on
    Thank you, it works! But a bit different. Cutout Opacity was set on 1.0, i changed it to 0 and it fixed the situation. I'm pretty sure i didn't change this parameter before. And it's default setting in my case was 1.0. Maybe this option works differently because in your screenshot there is preset with two curls, and I have one.
    1044 x 421 - 499K
    Default 1.0 works well on my side. I don't know why it didn't work for you... Setting it to 0 make the hair cap invisible...
