dForce hbc24 Santa Suit
Kev914Kev914 Posts: 1,145
Does anyone have this suit? And do you have any problem using it?
https://www.daz3d.com/dforce-hnc24-santa-costume-outfits-for-genesis-9
My problem is with the boots. You load them in two parts. That works fine. They look fine. If you preview them in iRay, they look fine too. But when you render them, the furry part at the top of each boot offsets. They render about half way down the boot and half way off to the side; the one to the left and the other to the right.So they are half on half off. I saw the fur was fitted to G9. I tried fitting them to the boot tops instead. But that didn't help. I even deleted them and reloaded but that didn't work each. So I ended up just hiding them. Might go back today and try to just parent them instead of fitting them.
Thanks.
  • The video from the product page might have the solution:
  • felisfelis Posts: 6,552
    Strange.
    Unparenting is needed if a user creates a SBH, but I have never seen it necessary for PA SBH.
  • crosswindcrosswind Posts: 10,324
    edited December 2024
    It's a bit weird the PA created those fluff with the user-oriented SBH Editor ~~
    AFAIK, SBHs made with SBH Editor shouldn't be parented to figure's root node otherwise there'll be wrong transforms ~~
    Post edited by crosswind on
  • Kev914Kev914 Posts: 1,145
    Yes, the video is the answer. Thanks Catherine and everyone who answered.
