DIM crashing when I try to download items [SOLVED]
abelundercity_7fb40cbc22
[DIM crashing when I try to download items] It's especially annoying considering that I'm taking advangtage of the Advent calendar offers. I've attached the crash log. Any help would be appreciated.
Post edited by abelundercity_7fb40cbc22 on
According to the log a lot of your sessions end with an issue opening a file, and the error ends
The process cannot access the file because it is being used by another process.
The XML file also refers to an opening check as the active process. That suggests that something (disc error, disc space, access permissions, security software) is blocking DIM and so causing a crash. Try a test run using another download or install location, if possible on a different drive, and see if the error persists.
Thanks for the tip! It was my antivirus being overly protective.
