Diffeo and german windows OS
Masterstroke
My installation of Diffeo is failing and giving error messages, most likely because of my german language windows OS.
Some files should go into C:/user/<username>/documents
but german OS only knows C:/Benutzer/<usernameY>/Dokumente
Has anyone german has been able to succesfully install Diffeo?
...and how?
EDIT>
changed OS language, still doesn|t work.
So I am clueless.
Post edited by Masterstroke on
Be sure to update, then you can choose the settings folder in the addon panel, if the default doesn't exist.
https://bitbucket.org/Diffeomorphic/import_daz/downloads/
The path that Windows shows in the title bar is not the same as the name that Windows uses internally. I'm using Swedish Windows, and my document folder is presented as "C:\Användare\Comsol\Mina document" but the internal name is "C:\Users\Comsol\Documents". You can see the internal name by right-clicking on the address bar. File selectors in Blender only uses the internal name.
Your problem is probably that the root paths are not set up correctly. Try follow the guides in https://bitbucket.org/Diffeomorphic/import_daz/wiki/Installation Guide.
Never had a problem installing Diffeo on German Windows. Works quite well here.
Thanks for your answers and links.
What other solutions are there for exports to Blender, if I want my character(s) and scene just like in DAZ Studio?
I don't really need to have animations. I am mainly looking for an alternative render stage.
With diffeomorphic you can export posed scenes via dbz, including shells and geografts as well as HD shapes. In general the materials will be quite similar to iray, but there may be exceptions you will have to tweak.
