[Released] Anilip3 [Commercial]
2»
  •  Can Anilip3 use Japanese?
  • DobitDobit Posts: 207
    lorddayradon said:
    Dobit said:
    At the moment, it is mainly SAPI voices that support extended SSML tags. Both from Microsoft and from third-party providers
    I have not be able to identify SAPI specific voices in order to suggest that a voice may be more compatible with SSML tags.  Is there a way to do this within your api?
    Dobit said:
    We are still working on giving neural voices better SSML support, but do not yet have any productive solutions.
    By coding/training it yourself, or relying on the voice models trainers/creators to do the work, and once they complete it, you can add/replace the freesource model with the updated one? If you are relying on the original trainers/creators, how many of them that you are using are still actively working/updating the models you use?
    All voices have a prefix in brackets. Neural TTS, Microsoft Windows SAPI Voice, Microsoft Windows TTS Voice. The last two have extended SSML support. You can also install additional English locales in Windows (e.g. UK), then you get additional voices (See example image for UK with Anilip3 Neural Voices extension for English). There is a chapter about this in the manual.
    We use Piper as the technological basis for Neural Voices. This is an open source project with an active community. The developers have announced extended SSML support. In addition, we are testing ways to use features such as changing the pitch or speech rate independently of the engine used. Then a voiceover could also benefit from this.
    978 x 867 - 262K
    1108 x 585 - 183K
    Unfortunately, we do not currently support Japanese or Chinese.
  • ImagoImago Posts: 5,686
    There's a trick for that: use italian plugin and romanji translations.
  • Hi, I am not getting any Facial Expressions with my dialogue. Are there any special setting (ie graphics card ets) that have to be deployed?
     You don't get lip animation? Then it's best to contact our support: [email protected]
  • ArtiniArtini Posts: 10,359
    edited November 2024
    I am trying it on Windows 10, but do not get any results to show, yet.
    Will upgrade to Windows 11 to see, if it makes any difference.
    Post edited by Artini on
    Does anybody know how to get video with sound saved?
    Render an image sequence (which is a good idea for multiple reasons) then assemble the video and add the sound track in a video editor.
    Thanks, Richard. I have thought, that it will be somehow aotomated by the Anilip 3 package.
    What does this error means:
    "The figure control with name 'VSMMouthL' could not be found. Check your configuration."
    and how to fix it?
    According to https://www.daz3d.com/anilip3-figures-pack
    Daz Horse 2 should work with Anilip 3.
    I have used https://www.daz3d.com/da-clydesdale-for-daz-horse-2
    and it created an animation, but I could not transfer a voice to it.
    1576 x 829 - 187K
    Anilip 3 works with Genesis 9 characters, but not with Daz Horse 2.
    At least I have not found a way how to use it, yet.
    1920 x 1080 - 226K
    Here is a file with my first Anilip 3 animation - you need to unzip it.
    zip
    zip
    Vicky9sc04a02.zip
    4M
    and how to fix it?
     We'll take a look at it. Horse 2 should of course work with the Anilip3 Figures Pack.
    Thanks for the response, @Dobit
    I have also tested:
    https://www.daz3d.com/daz-horse-2 and https://www.daz3d.com/daz-house-cat-with-dforce-hair
    The same error appeared, as well.
    Maybe I am just making some mistake with the animal figures and Anilip 3.
    If so, please write some short instruction about how to use Anilip 3 with the animals supported
    by https://www.daz3d.com/anilip3-figures-pack
    Thanks in advance.
    One more thing. When I use Anilip 3 with Genesis 9 the timeline is automatically adjusted to the speech length time.
    With animals the timeline stays at the default value.
    and how to fix it?
    There is a problem with Horse2 and the phoneme L. We will provide a fix. In the meantime, you can help yourself. Open the file <Daz Library>\Anilip3\Animation Presets\DEFAULT\skeletons\Animation V16 DAZHorse2.dbmf in an editor. Replace "ControlName": "VSMMouthL" with "ControlName": "VSMTongueL"
    Save and restart Daz Studio.
  • I bought Anilip3 but can't use it. after activation and restart Daz studio, I get the message: Your licence key could not be validated. Check your license key and try again or contact the Dobit support. I have tried several times but without success. Request for a solution.
    Thank you very much, @Dobit
    Now Anilip3 works for me with Daz Horse 2.
    You send us a private message and we answered this mesage. Please look in your inbox.
    Doesn't look very precise... Or it's just a super quick test?
    It was just a super quick test.
    Still need to learn and experiment with Anilip 3 much more.
    I like that I can get results from Daz Studio almost directly
    (besides combing video and sound in the external video editor).
    Below is a test with Daz House Cat.
  • RandWulfRandWulf Posts: 216
    edited February 2025
    I am brand new to Anilip - I just got the Anilip3 bundle.  I've watched the bundle and read the manual, but still don't know how to preview the dialog file, or tie the audio file to the animation so it renders all together.
    Post edited by RandWulf on
    I worked it out.
    Does anybody knows if
    https://www.daz3d.com/reverb-presets-for-anisound
    works with Anilip3?
  • MoogeeMoogee Posts: 72
    Help.
    Recently purchased the AniLip3 bundle. Installed using Daz Install Manager and everything when as planned. Looked in Plugins and its there showing its plugged in but the dialogue box for the serial number isn't showing up. I'm using the most recent version of studio 4.23 and was wondering if this has anything to do with.
    Many thanks.
    works with Anilip3?
    You can download the sound file for each text2speech dialogue and use it as a sound source in Anisound. Then you can also assign the reverb setting in Anisound.
    Moogee said:
    Help.
    Many thanks.
    In Anilip3, the serial key is entered in the plugin itself. So, first create a new pane with Anilip3 and then enter the key there.
    Cheers Dobit. Now activated and working. Thank you :)
    Im in a similar boat. Purchased the Anilips3 bundle, but Daz wont run it. When I try to access it I get a page telling me to "enter the license you were provided when purchasing" but nothing on my daz order details says anything about a license. Nor does my product library page (although the product library page does show the anilips 3 bundle there). Ive emailed dobit support. Waiting to see what they say.
  • skybluerobskybluerob Posts: 14
    edited January 15
    Hi.  My Daz Studio updated today, and the Anilip Plugin is failing to load.  It gives the reason:  Library could not be loaded.  File is not a valid DAZ Studio plug-in or was made for a different version of DAZ Studio.
    Is anyone able to help?
    UPDATE:  It seems to be working now, so please ignore this.
    Post edited by skybluerob on
