New Year, New Sales Thread: Report Issues Here "Reporting Only"
1…6667697172…101
  • Nath said:
    Cris Palomino said:
    Editorial licenses revoked on the two above items.
    Great!
    However, another issue: there are no install types/download links for
    https://www.daz3d.com/looking-for-poses-for-genesis-9
    and
    https://www.daz3d.com/hat-check-for-genesis-8 ;
    Will report.
  • NathNath Posts: 3,060
    Cris Palomino said:
    Nath said:
    Great!
    and
    Will report.
    And they're working now!
  • WISH-AND-GET Doesn't work on any "New" items
    *Items must be found in your Wishlist prior to NOV 27.
    Cannot be used to discount items already owned.
    Coupon Code usable once per customer.
  • frank0314frank0314 Posts: 15,114
    Are you adding the new items from the link provided, or just some random new items? That code doesn't work on new items. It's only for the items within the link provided, and it also needs to be in your WL. For new items, you need to use "WISH-FOR-NEW-STUFF" from the link provided. We will see about getting the clause added to the exceptions.
  • WISH-AND-GET isn't working for me on items that are NOT new. I'm selecting from the 'current items' link provided and the items have been on my wishlist for ages.
    Can you provide the links for some items not working with WISH-AND-GET?
    Here's a couple: https://www.daz3d.com/karmen-9-hd-pro-bundle https://www.daz3d.com/kuj-fashion-cute-suit-for-genesis-9
    edited November 2024
    Can you show us your cart so we know what else is in there to see if there are any conflicts?
    Edit: You also can only pick products from the link provided "Shop Now"
    Post edited by frank0314 on
    I know you can only use it on items in the shop now link provided. What isn't clear at all is that you can only use the code on ONE of the categories (current, recent, legacy). I've now found that out for myself.
  • ElorElor Posts: 4,160
    It's working for me with a caveat (a big one): if the cart have items from two or more selection, the coupon will only apply to items from one selection (always the selection with the bigger discount, so with items from the 60% selection and 70% selection, only items from the later will be discounted by the coupon):
    I added an item from the less discounted selection first and it was discounted by the coupon.
    Then I added an item from the second selection, that item was now discounted and the first now wasn't anymore.
    And after I added an item from the most discounted selection, only this item was discounted by the coupon.
    As the coupon is one use only, I don't think it's how it is suppose to work.
    1298 x 211 - 28K
    1314 x 361 - 42K
    1304 x 491 - 56K
    Post edited by Elor on
  • Also, the Daz+ weekly freebie for this week - Is it incoming or did I miss the memo? I thought it was normally out already by this time but maybe I'm wrong...
  • KerseyKersey Posts: 111
    I had the same problem. Can only use the coupon (WISH-AND-GET) on one section. Adding items from two sections will only discount items from one of them.
    I think one cart per category would solve the issue.
    Only if we could use the coupon three times (or if they added one coupon per category, usable once, if they want to avoid people using it three times on the 60% selection), but it's a one use only coupon.
    Looks like they'll be going out on Friday/Saturday.
    Thanks, Cris :)
  • I have the same problem, only one item is discounted but it does not work on the other items from my wishlist.
    I have added some of them one to another to the cart, it does not show any discount, I had to withdraw from it.
    Can you please at least fix this? My wishlist is 12 pages, only I need to select the ones I will use for the renders and the situation is a total headache because I can't put anything else as the coupon is to be used only once sad
  • yes it was multiple catagores not working in my case too as added the oldest one first
  • Halcon BlueskyHalcon Bluesky Posts: 733
    This situation is really messy, I desperately need some items, I don't want to end up with nothing
    Post edited by Halcon Bluesky on
    Are you selecting items from those in the category pages or just from your wishlist?
  • Each category has a "Shop Now" link, and below "View Wishlist"
    I went to my wishlist
    The 70% off category has 227 long pages to browse this will take an eternity.
    Putting a tick in "Only Show Bundles" reduces it to 11 pages
    I will have to look up again frown
  • I use the method, add all wishlist and it will only apply to eligble for most things
    as long as one thing is valid, my wishlist short devil
    but if only one catagory working then that's not as simple as there might be things it would work on
  • WandWWandW Posts: 2,907
    This is the silliest Wishlist sale ever.  Since one cannot filter by Wishlist, unless one wants to look through tens of thousands of items, the only way to shop this sale is to put in the coupon code and stick random W/L items in the cart to see if they discount.  No Thanks! I have better things to do.angry
    Also, since many recent sales require a coupon code, one cannot use Membership Coupons.  I still have mine.....  sad
  • Phoenix1966Phoenix1966 Posts: 2,015
    Has this been addressed yet? As others have pointed out, it is a single use coupon. So, do we just pick one category discount or is the coupon not working as intended since you cannot successfully apply it to a cart containg items with different discounts?
  • FauvistFauvist Posts: 2,291
    I REALLY REALLY appreciate that my Commons Forum post from a few days ago about "some people only buy from their wishlist" may have influenced this wishlist sale today.
    The problem is that there are 35,000 items that may be on sale if they are in your wishlist - but there's no way to determine if they are on your wishlist.  Can't you just indicate the discount percentage next to each item ON OUR ACTUAL WISHLIST?  Nobody's going to scroll through 35,000 items, especially if there is no indication that any of the items your scrolling through are on your wishlist.
    The other thing is that there is no indication ON OUR ACTUAL WISHLIST of whether any item is in the Current Items, Recent Items, or Legacy Items category.
  • Richard HaseltineRichard Haseltine Posts: 111,681
    The WISH-AND-GET code should now work on a mixed cart, discounting all of the included WL items to the intended level (my WL is too small to test). Sorry that it wasn't working correctly earlier.
    Today there is also a sale banner offering 65% Off a couple of  Featured Artist store items, but there is no Featured Artists today - if there are, where's the link to them?
    This is the page I get taken to when I click on the "shop now" button for that offer: https://www.daz3d.com/fourth-dimension-artists#index=0&order=popular^1&filtered=1
    I got that orange banner yesterday and can see no expiration date for the offer, so not sure if it is still valid.
    Post edited by Phoenix1966 on
    I tested and it's applying the correct discount to a mixed cart. Thank you.
    1328 x 467 - 58K
    It didn't work for me
