Starting lights (headlamp?) seems broken...
To add to my other problems (search the forum for the adventures), there seems to be something wrong with lights in Daz.
The picture below is just opening the program, loading v4, hitting render (3delight is set).
The pic looks wrong..dark...
Things worked fine last night..nothing happened that I'm aware of...
Renderer is set to headlamp when no light is present.  With it set to never, I get a solid black figure..
  • I see light - not very bright, but there is light.
  • ScavengerScavenger Posts: 2,677
    edited September 2015
    That's not the standard light.
    Pic 1 is from a week or two ago character loaded, camera moved, picture taken.
    Pic 2 is from just now.
    798 x 775 - 433K
    1200 x 776 - 372K
    Post edited by Scavenger on
    In the Render Settings check the Gamma and Gain settings...if gamma is on, it should probably be 2.2 and gain should be 1.0.
    That helped.. Gain was at 1, gamma was on and was at 1.
    It still seems off a bit, but better!
    1200 x 776 - 430K
    Well, something reset during my rebuilding (see other problem threads) and it's working right again.
    The setting is Gamma set to 1, but turnerd off. Gain at 1.
    1200 x 776 - 320K
    Seems to flip on and off randomly...have to watch this closer.
