• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Iray section planes for Blender?
DrGonzo62DrGonzo62 Posts: 382
November 2024 in Blender Discussion
Hi,
Is there a funtionality in Blender similar to DS Iray section planes to cut down on render times?
An add-on maybe?
Thanks!
  • PadonePadone Posts: 4,024
    November 2024
    booleans ?
  • DrGonzo62DrGonzo62 Posts: 382
    November 2024
    Padone said:
    booleans ?
    As in per object you want to hide from the renderer?
    In DS you just add a section plane and all geometry behind that plane will be hidden from the renderer.
    I didn't get far enough into Blender to know if you can do a bool on a collection or not, but I would be surprised if you can.
    November 2024
    Yes you can do collections on booleans, if you just look at the modifier you see the options.
    November 2024 edited November 2024
    The problem for me is, that any mesh lighting gets hidden as well.
    So I can no longer just render a section of a scene and composite it afterwards, since the lighting no longer matches.
    Something you can easily do in DS.
    Post edited by DrGonzo62 on November 2024
  • WolfwoodWolfwood Posts: 876
    November 2024
    As strighforward as section planes i don't know. But a search on the subject pointed me to what appears (haven't tried it) to be a clever way to use geometry nodes to do something similar:
    https://blender.stackexchange.com/questions/284371/hide-instances-outside-of-area
    November 2024
    Thanks for the feedback.
    DS section planes can hide geometry from the Iray render engine, but retain the light emitted by that geometry (clipping lights on or off).
    Like part of a ceiling emitting light. You can hide the ceiling, but still keep the light provided by it.
  • crosswindcrosswind Posts: 9,621
    You may try using Clipping Plane in Bonsai's BIM extension. It's a free extension you can directly install in Blender.  https://docs.bonsaibim.org/quickstart/installation.html
    The clipping plane can be found under Quality tab.. It's still an experimental function but it'll work.
    2560 x 1392 - 1M
    Post edited by crosswind on November 2024
    November 2024
    Looks interesting, thanks!
  • KitsumoKitsumo Posts: 1,222
    November 2024
    This isn't the exact same as an Iray section plane, but you can kind of get the same effect.
    November 2024
    I'll check that out, thanks!
    Hi,
    I played around with this today, and while this clipping plane works pretty much the same as an Iray section plane, it did not reduce render times as far as I could tell.
    While geometry is hidden behind the plane, it seems that it still gets fully considered in the render, it's just no longer being displayed.
    For example, one of my scenes that takes 13 minutes to render in DS, will take only 3 minutes with a section plane behind the camera, and looking exactly the same.
    I played around with camera culling in Blender as well, but I couldn't really achieve the same reduction in render times that I can get using Iray.
  • Richard HaseltineRichard Haseltine Posts: 108,465
    November 2024
    Hi,
    Iray section planes are actually designed to work the same way, as far as I know their default behaviour is to hide geoemtry from the direct camera view but leave it present for shadows, relfections etc. so that ytou can see into an enclosed space but still have it render as if complete. Daz chose to make them work the other way by default, so that the clipped items are completely hidden, as peoiple seemed most interested in the feature as a way to get light into closed spaces.
    November 2024
    Thanks for that explanation, Richard!
    I often render an animated object fully enclosed by 5 or 6 section planes for later compositing over the scenes static background image.
    I couldn't render longer animations without this feature, even with 3090 cards.
    November 2024
    Hi,
    I don't think that clipping plane has this feature of like Iray section plane... as cycles engine is differenct from iray engine after all. But there're quite a few ways to speed up rendering in Blender and lots of tutorials there on youtube.
    You may try those tricks as needed ~~
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
