Daz Studio BETA - version 4.23.0.4! (*UPDATED*)
1…1415161719
  • crosswind said:
    UV Set is not saved in the Material Preset of a geoshell, as well as in Hierarchical Material Preset. There's no such issue with Figures / Props.
    Edit: Besides 4.23 GR / PB, same issue happens in 4.22.0.16 ...
    Could you please provide steps you took so I can try and replicate. Thank you.
  • crosswindcrosswind Posts: 10,347
    edited November 2024
    As what I showed in mypost, the first screenshot. Can you see that ?
    Load a geoshell on a G8F,  choose a UV Set on a Surface,  save a material preset with the surface and UV Set selected. Thanks!
    Post edited by crosswind on
    Geoshells don't inherently have any UV's. They get them from the figure they're attached to. The best way to do that would be to set up the materials on the figure, then save them out from that and apply them to the geoshell (or edit the file).
    GeoShells still have thje UV sets available, and those can be set independently from the base.
    Available, yes, but not as part of themselves. That data is on the base. Geoshells are dynamic and created from the base when they're made, so  the data from the base is there, but they don't have UV's of their own. You can see this demonstrated by saving one as a new figure/prop asset. You'll notice there are no UV (or morph) definitions saved with it. The same geoshell that would cover a primitive cube would cover a G8F. Whatever the active UV is on the base is what the Geoshell will come in with. You could do a postload script to change the UV after it's loaded though probably.
    Thanks! Yes, I know UV map is made and saved on Genesis figure and then adopted by a geo-shell. But what I'm talking about is Material Preset...
    I was making different UVs for a single geoshell to make it as a "modular shell garment" so as to have diffrent Styles / Materials, then I would set up Material Presets to change Styles and Materials on the shell. So the UV Set need to be changed by loading a Material Preset on the shell. And I think it's a very common demand... but Material Preset failed to save the value in UV Set slot.
    Well, since there's the option of saving Geometry > UV Maps > UV Set in Material Preset Save Options dialogue, I thought it could've and should've got the job done. I've sent a ticket and the Daz guy reproduced the issue and thought it's a bug as well. And I believe it'll be easy to fix it ~~
    BTW, standard Post Load script cannot do the job...because it also has to load a Material or Property Preset to change UV Set but they'd both fail... so I have to specifically write one ~~  If a Material Preset can easily get it done, I won't have to do so...
    BTW again, all of a sudden, I got responses from Daz for the multiple tickets I ever sent before... The guy has concretely replied the test results and the following actions. I was very happy to see that 'cause at a moment I felt I was a true customer...
    Appreciate the attention and improvement you guys have paid and done !
  • ImagoImago Posts: 5,801
    Please, Devs, fix the crash on load with big scenes! I can't even load a scene without closing DAZ Studio first!
    The Batch renderer is useless now, every time it changes scene after finishing the render, I get an error window blocking the whole task!
    I said this so many times that I'm starting to feel dumb!
    The crash happens when DAZ Studio has a big scene loaded and starts loading another scene (you know, batch scene rendering) and looks like it happens more often when there's something altered with Mesh Grabber 3 in the scenes.
    The error is on Dazcore.dll, Tbb.dll and some Windows internal DLLs. It's really easy to reproduce, just load a big scene with many elements in it and then with any method (double click on file manager, load or recent from File Menu) load another big scene. By big I mean scenes with at least 100Mb of data, not a simple cube alone.
    Post edited by Imago on
    I guess not many people have scene files that big. I loaded a scene (177MB), then File - Open and loaded another scene (183 MB). Finally, File - Recent and reloaded the first scene. All good.
    Try adding some stuff altered with Mesh Grabber 3 and not baked to moprh (don't use the "save" option in the Mesh Grabber panel), some animations and retry.
    The crash happens in DAZ Studio 4.23 and 4.22 but not in 4.21, so I'm pretty sure I'm not doing anything wrong.
  • Same kind of issue...
    I debugged so far and got the following conclusions:
    Starting from scratch with new model (GEN8) old environment (worked good since 4.20) like medieval town... the UI starts to be frozen (have to kill DAZ) when I add second camera.
    Each of my old works have lot of cameras (sometimes 20) it is impossible to work back on them...
  • You need to give more specific details in order for anyone to troubleshoot this.
  • Since update to 4.23: all projects from 2020 can not be worked on (because all the ui is frozen).
    From scratch: i can do stuff untill a camera is added.
    Once added either with "copy" or "apply" --> ui is stucked.
  • Which details can I give ?
  • Another example: a old subset that has always worked can not be opened with no error in logs , no error messages nore warnings...
    The UI tab "scene" is empty (there is 12 cameras in it)... i got the same subset without cameras -> it loads with no errors no warnings either screen or logs and the tab "scene" is ppopulated.
    I can move, modify parameters until I add a camera.
    I completly wiped out all related to DAZ 3D and it took one week to reinstall the whole stuff.
    I lost a hard disk with ressources that i'm not sure to get it back even they were paid (got to retreive the orders) so concerning the ressources I don't think it is the point as IT ALWAYS WORKED BEFORE.
    I got two "splashes" at the launch of the app that flashes and disappeared but impossible to freeze the screen as they vanished too quickly, it seems like some "progress bars"... never seen before as there is no error in logs...
    txt
    txt
    log.txt
    37K
  • Richard HaseltineRichard Haseltine Posts: 111,867
    Could you post a screenshot with the Scene pane option menu>Show opern, like this
    528 x 637 - 49K
  • felisfelis Posts: 6,603
    I have not observed that.
    Is the UI lagging or frozen?
    Lagging is usually caused by an object with high subD or high smoothing.
  • Another workaround: with the same subset containing 12 cameras...
    I edited the .duf file (it took 15 minutes), I wiped out all stuff related to cameras... now ui is responsive.
    The issue is RELATED TO CAMERAS...
    367 x 507 - 20K
  • Could you attach one of the files that triggers this?
    I have merged your two separate threads into this one - please don't start mutliple discussions of the same topic.
    The sudden crashes when loading a scene bigger than 50Mb have been solved? I reported this but never got an answer...
  • jeffbdvsjeffbdvs Posts: 53
    edited December 2024
    Mac Studio M2 Ultra
    Apple Magic Mouse
    macOS Sonoma 14.7.1
    Daz Studio Public Build 4.23.0.4
    Opt + Cmd + RMB doesn't work correctly. Left/Right drag pans view as expected, but Up/Down drag zooms instead of panning. This works correctly in 4.22.0.19
    Opt + Cmd + LMB orbits as expected.
    (Edited for clarity)
    Post edited by jeffbdvs on
  • frank0314frank0314 Posts: 15,115
    jeffbdvs said:
    Mac Studio M2 Ultra
    Apple Magic Mouse
    macOS Sonoma 14.7.1
    Opt + Cmd + RMB doesn't work correctly. Left-to-Right drag pans view as expected, but Up-and-Down drag zooms instead of panning. This works correctly in 4.22.0,19
    Please submit a ticket to tech support so they can look into it.
    Done.
    jeffbdvs said:
    Done.
    TYVM, and thanks for pointing it out.
  • jeffbdvs said:
    Mac Studio M2 Ultra
    Apple Magic Mouse
    macOS Sonoma 14.7.1
    Update. 4.23.0.4 may have changed the default mouse button modifiers. I reset the orbit, pan and dolly modifiers to match what was in 4.22.0.19 and now all is working as expected. Still, it was odd that that particular combo worked correctly in one axis but not in the other, regardless of which modifiers were used.
    NB: I only stumbled upon the option to change the mouse button modifiers because I was modifiying my workspace. If not for that, I don't know that I would have ever found the option. It's here: Window>Workspace>Customize>View Controls tab.
  • TotteTotte Posts: 15,224
    Tested on my macOS 14.7.1 with latest build and it seems to work.
    What are your settings here?
    1032 x 130 - 31K
    1032 x 103 - 26K
    1046 x 114 - 37K
    406 x 316 - 54K
    Post edited by Totte on
    Hi @Totte
    Thank you for taking the time to provide those screenshots! We Mac users have to stick together. laugh
    My setup (after tweaking) is the same as yours, but with one addition/change to the Dolly keyboard/mouse combo:
    The default keyboard/mouse combo for Dolly was Cmd+Alt+RightMB when I installed 4.23.0.4. I could Dolly by swiping the surface of the Magic Mouse, but using the default keyboard/mouse combo resulted in my "split axis" behavior problem. Forcing Dolly to Cmd+Alt+MidMB solved the problem for me, and I can still Dolly by swiping. (NB: I used the Mac app "Middle" to send the middle button command to Daz.)
    The Zoom (Dolly) shortcut you showed (Cmd+Shift+RightMB) also works. But I'm faster navigating by swiping to Dolly and only using the Cmd+Opt keys for Orbit and Pan.
    Cheers.
    Any chance to see the crashes when loading big scenes solved?
    I reported this many times and still got no answer from the helpdesk.
    The problem is most likely that it only happens under certain circumstances, e.g. in your case stuff altered with Mesh Grabber 3 and not baked to moprh (don't use the "save" option in the Mesh Grabber panel), some animations. It doesn't appear to be consistent.
