morphs of deleted assets still showing up in parameters sliders
bpfrocket
In an effort to streamline my content and hopefully speed some things up, I have uninstalled several figures from Daz Studio. When I search under the parameters tab, sliders still come up for them (See attached) I have looked for them in the Data folder and I couldn't find them. I've even done a file search in the folder for the name and come up empty.
Thoughts? Ideas? Quick, brainy solutions?
Not sure if it will work but have you tried clearing the DSON cache files? If you go into Preferences (F2) then there is a button to do it on the general tab. I'd remove all figures from your scene before you try it tho.
After uninstallation, DSON cache should be auto updated when loading figures... so I suspect if there's another copy of DSF files. As for such a case, you can always 1stly check it by clicking that Gear icon on the right of Alawa 8... property > Parameter Settings.
Then check if there're still DSF files in the File Path... as the attached ss ~~ If there're still residual DSF files, delete them from there and reload the figure.
Thank you both.
Cleared DSON cache and that didn't do it, but checking the parameters setting sent me to the right place and I did a manual delete of leftover file.
