morphs of deleted assets still showing up in parameters sliders
In an effort to streamline my content and hopefully speed some things up, I have uninstalled several figures from Daz Studio. When I search under the parameters tab, sliders still come up for them (See attached) I have looked for them in the Data folder and I couldn't find them. I've even done a file search in the folder for the name and come up empty.
Thoughts? Ideas? Quick, brainy solutions?
370 x 363 - 56K
    Not sure if it will work but have you tried clearing the DSON cache files? If you go into Preferences (F2) then there is a button to do it on the general tab. I'd remove all figures from your scene before you try it tho.
  • crosswindcrosswind Posts: 10,249
    After uninstallation, DSON cache should be auto updated when loading figures... so I suspect if there's another copy of DSF files. As for such a case, you can always 1stly check it by clicking that Gear icon on the right of Alawa 8... property  > Parameter Settings.
    Then check if there're still DSF files in the File Path... as the attached ss ~~ If there're still residual DSF files, delete them from there and reload the figure.
    559 x 689 - 66K
  • Thank you both.
    Cleared DSON cache and that didn't do it, but checking the parameters setting sent me to the right place and I did a manual delete of leftover file. yes
