[Looking for asset] Basic, featureless, rigged humanoid for Daz 4.5
Hi there!
After spending a ridiculous time looking, I'm humbly asking for your help in finding a basic, featureless, DAZ rigged humanoid model. I do a lot of visual for Saudi market, hence it cannot have any features even remotely considered nudity. This: http://www.turbosquid.com/3d-models/3ds-max-generic-male-base-mesh/744199 Would be a perfect reference. It doesn't have to be free, just clean, simple and poseable in DAZ.
Any ideas? Thanks for any possible help
  • ScavengerScavenger Posts: 2,674
    Well the grid mesh you could just make a map and stick it in all the diffuse slots.
    The base genesis (1) figure is sort of androgynous putty looking.
  • kubakuba Posts: 4
    Yes, but it has facial features, a defined groin and toes at its feet. All I need is basically a neat looking manequin.
    Anybody?
    Anybody?
    Your best bet is to morph Genesis. Anyone with a decent modeler and a little patience should be able to do that without a whole lot of issues. A quick pass in ZBrush or Mudbox with a flattening tool would serve, or the sculpting tools in Maya LT.
  • kubakuba Posts: 4
    Yep, that was my guess.  GoZ for the win! Thank you guys for your advice, but still, keep an eye peeled for some basic humanoid model, will ya?
    On a second thought, maybe youve seen a collection of human figures for architectural viz's? Basic, clothed human figures? Any for of info appreciated and again, doesn't have to be free.
    Peace!
  • if you remove the textures from the DAZ base figures, you should have pretty much what you need.  If all you need is the male, the figure has no genitals.  If you need to use the female, she can be used without nipples and the genital area, again, is not defined.  If all you're doing is visualizations, you can just use clothing or textures or no textures at all, again, if all you need is mannequins.
  • SpitSpit Posts: 2,342
    Peace!
    Have a look at Predatron's lo-res figures.
    http://www.daz3d.com/lorez-figures-modern-males
    Much more than that... http://www.daz3d.com/catalogsearch/result/?q=lorez
  • FSMCDesignsFSMCDesigns Posts: 12,853
    Peace!
    The biggest issue with any figure outside of DS is the rigging. I have imported lots of FBX and collada figures into DS and none of them had working rigging due to the proprietary way DS does rigging, so your best bet is starting with a DAZ figure or rig it yourself.
  • UthgardUthgard Posts: 889
    If you don't mind going from basic and featureless to toon, there are these options:
    https://www.daz3d.com/stickman
    https://www.daz3d.com/blank-boi
  • they said archviz, so toons don't work for that.
  • kubakuba Posts: 4
    Thanks a lot guys! Really appreciate your help.
    I'm very surprised that there's nothing as generic as that out there! Spent hours looking as I'm pretty clueless on how to righ stuff in DAZ...
    Thanks a lot for your effort and please, try keeping your eyes peeled for some of that stuff. It might be pretty helpful at times.
    Peace!
  • larsmidnattlarsmidnatt Posts: 4,511
    edited September 2015
    there isn't a huge demand for stuff that generic, probably why you don't see a lot of it. best bet as others have said is the base genesis figure which is neutered.
    I would think the lorez figures should do the trick otherwise.
    Post edited by larsmidnatt on
