Adding to Cart…
I believe all that was said was that not listing Poser under compatible software was because there are no PCF's. I don't recall anything one way or the other about whether there was some reason it would not be possible to create PCF's and Poser-optimized materials. But I may have missed or misunderstood something.
Yes, you can use Scott 6 in Poser and I dialed Michael 6 from 1 to 0.5 because together with 1 for Scott the chest part really looked weird upon loading. The nipple fix is really needed and don't forget to use unhide dials for it. It's a long list but you'll find it.
You really don't need "Poser-optimized-materials" if you use EZmat by Snarlygribby and Bagginsbill because it optimizes the textures just as for other characters.
In the render I left the dial for M6 at 1. But I used the nipple fix and the chest morphs M6PecSmoother1 at 1 and M6PecSmoother2 at 0.3 .
Scott relaxing by the pool side :)
Great render!
CHEERS!
