My Favorite Script (Commercial)
2
  • Zev0Zev0 Posts: 7,123
    crosswind said:
    @Zev0
    After applying the saved Pose preset, the values in Scale of some joints are not correctly set (doubled to 200%)... probably a bug.
    JSON file is attached. Ticket has been sent as well. Thanks in adv.
    Just a note if you stack a pose preset that can happen on morphs if limits have been removed on them somehow...If you Zero pose before applying that should correct the issue, unless there is a real bug somehwere.
  • crosswindcrosswind Posts: 10,156
    edited November 2024
    Zev0 said:
    crosswind said:
    @Zev0
    Nope, I didn't stack the pose. The preset was just applied via Favorites Script to a freshly-loaded G8F dev load.
    I attached a Scene file down below as a test case. The issue can be simply reproduced. BTW, Always Leave Limits On is set in Preferences.
    You just save a Pose Preset from Genesis 8.1 Female - Source, then apply it on Genesis 8.1 Female - Target
    Video of Issue: https://mega.nz/file/DfISFYZJ#xhevxjpW4lFJREVZYNUfX6GSU5YlJKJ6DY3Ycvr0uL4
    duf
    duf
    CYY1.duf
    191K
    Post edited by crosswind on
    No issue here. Can another user please try and duplicate using the provided scene file above? Thanks.
    Post edited by Zev0 on
    Thanks for the test ! I probably know the culprit ...
    1)  On my side, for instance, I select the bone - Right Forearm Bend, for some reason the Scale value there is not default 100% (screenshot 1), as well as in Pose Preset (screenshot 2)..
    2)  I Alt + Click the Scale property to reset it to default 100%, re-created a new Preset with Favorite Script, then the issue of "doubled Scale value" on Right Forearm Bend is gone. (screenshot 3)
    But then I don't understand why....
    Would you pls also check Right Forearm Bend > Scale property ? Is it a non-default 100% as well on your side.... ?
    Edit1: Then I rechecked the JSON files, in the original Preset file, there's Scale data of rForearmBend (screenshot 4), but in the newly-saved Preset file, there's no Scale data (screenshot 5). The latter gives me correct result.
    So, pls also check the saved Preset file on your side... Thanks !
    Edit2: I reset Scale values on all relevant Bones and redid the process, the issue was totally gone ~ So I guess the script might handle Scale values in a specific way... Pls dbl-check.
    2560 x 1392 - 553K
    2560 x 1392 - 159K
    2560 x 1392 - 445K
    2560 x 1392 - 190K
    2560 x 1392 - 188K
  • takezo_3001takezo_3001 Posts: 2,039
    Downloaded and firing up DS as we speak.
    Mine is default at 100 on my figure.
    917 x 923 - 53K
    In Parameter Settings, I have the same data as you do but in Parameter list and Pose Preset, the end value is not pure 1 but 0.9999985 ~~ (Screenshot 1)
    @Zev0
    Edit: Here's a simple test. If I manually set Scale value to 105% on Right Forearm Bend of the Source figure, then Scale value will be set as 205% on Right Forearm Bend of the Target figure... after applying the Preset via Favorite Script. (Screeshot 2)
    So, I think you can reproduce this issue in such a way and I believe there must be a wrong calculation for setting Scale value in your Script ~~ It seems the logic is that default or end Value 100% is added by raw Value 105% ... which results in wrongly-set 205%.
    2007 x 1374 - 397K
    2015 x 1293 - 412K
    I made a mistake and didn't mention earlier that it was G9 that was having its correctives zeroed along with the zero morphs tick box… So after some tests, it seems that G9 is indeed having it's corrective morphs being zeroed along with the zero morphs checkbox!
    I also see that crossfire has found the issue with G8.1, I'll see if G8.1 is having the same issue as G9…
    Nope, G8.1 remains unscathed, it was indeed G9 that was having its corrective morphs reset!
    552 x 520 - 48K
    2063 x 778 - 256K
    554 x 502 - 48K
    2007 x 768 - 251K
    2091 x 865 - 295K
    560 x 505 - 42K
    2003 x 869 - 288K
    549 x 506 - 42K
    Confirmed corrective morphs on g9 are going wonky...Will sort it out. G8 on the other hand works fine unless another user can duplicate the problem.
    Thank you takezo for the testing ! I will do another round of test after getting up, haha ~ devil
     Cool, I'm glad to read that, thankfully it seems to have an easy solution, at least for myy non-coding eyes...
    Sure thing, have a great sleep!
  • gramgram Posts: 68
    I've had this same issue happen on a Genesis 3 female figure, can you maybe check that as well?
  • bicc39bicc39 Posts: 589
    Works great, saves time.......Thank you!!
    takezo_3001 I sent you a pm.
    Checking it now, thanks!
    EDIT: Yep, it works!
    Post edited by takezo_3001 on
    Will submit update...Problem was the property 'body_ctrl_basejointcorrectives' was sneaking through and getting zeroed out.
     Cool, I'm glad you got it sorted, pesky little bug never stood a chance! ;^)
    [Stuff] like this always happens...Specially if a product is multi generational....Specifically with how the auto correction system works...But ye..Glad it was an easy fix thanks to your help:)
    @Zev0
    Could you reproduce the issue I sent the ticket for ?
    Here's a video to show how to reproducet it, just in case.... https://mega.nz/file/7SoGQRxI#95mAKYUgcSgYw5sPsr_JcH-MJYdULiTdWJ6gJZ-CviY
  • PlatnumkPlatnumk Posts: 682
    For some reason I can't even get the script to work
    2024-11-17 01:03:04.814 [INFO] :: Loading script: /Volumes/DAZ3D Library/My DAZ 3D Library/Scripts/Zev0/My Favorite Script/My Favorite Script.dse
    2024-11-17 01:03:04.898 [DEBUG] :: #MFS: d98749c1-215c-4968-9e28-74c4ffa15e0e
    #MFS:
    ////  Initializing My Favorite Script...#cbO3kT
    2024-11-17 01:03:05.032 [DEBUG] :: #MFS: #pOJe2U: Script General Info:
    2024-11-17 01:03:05.032 [DEBUG] ::    Script Version: 1.0 (Dev 13)
       Style: Darkside
       Support Thread: https://www.daz3d.com/forums/discussion/700931/place-holder-thread-commercial
       Selected Figure: Genesis9
       Saving Presets To (#i5oJ9Q): /Users/danielwright/Library/Application Support/DAZ 3D/Studio4/My Favorite Script/Genesis9
       OS: macOS Sequoia 15.0.1
       Bit Architecture: 64
       DS Version: 4.23.0.1
       DS Release Cycle: General Release
       Script: /Volumes/DAZ3D Library/My DAZ 3D Library/Scripts/Zev0/My Favorite Script/My Favorite Script.dse
    2024-11-17 01:03:05.032 [DEBUG] :: #MFS: #T0uOBx: Loading Presets Directory from disk...
    2024-11-17 01:03:05.033 [DEBUG] :: #MFS: #wfn4zs: Reading directory file: /Users/danielwright/Library/Application Support/DAZ 3D/Studio4/My Favorite Script/Genesis9/_PresetList.json
    2024-11-17 01:03:05.033 [DEBUG] :: #MFS: #V0MkQt: No directory file found. Exiting.
    2024-11-17 01:03:05.033 [DEBUG] :: #MFS: #qem7UI: No preset directory file loaded.
    2024-11-17 01:03:05.035 [DEBUG] :: #MFS: #wEHMDa: Creating preset list dialog box...
    2024-11-17 01:03:05.035 [DEBUG] :: #MFS: #EQknB4: Defining widgets...
    2024-11-17 01:03:05.045 [DEBUG] :: #MFS: #nonkDr: Laying out widgets...
    2024-11-17 01:03:05.060 [WARNING] :: Script Error: Line 359
    2024-11-17 01:03:05.060 [WARNING] :: ReferenceError: Can't find variable: getRscPath
    2024-11-17 01:03:05.060 [WARNING] :: Stack Trace:
        <anonymous>()@/Volumes/DAZ3D Library/My DAZ 3D Library/Scripts/Zev0/My Favorite Script/My Favorite Script.dse:359
    2024-11-17 01:03:05.064 [INFO] :: Error in script execution: /Volumes/DAZ3D Library/My DAZ 3D Library/Scripts/Zev0/My Favorite Script/My Favorite Script.dse
    Anytime, and thanks for the magnificent scripts!
  • icemage1993icemage1993 Posts: 86
    Very useful tool, great work Zev0!! By the way, is it possible to:
    +Zero every morphs in a preset.
    +Folder feature so you can organize your saved presets.
    Post edited by icemage1993 on
    The beauty of this script is that it completely negates the need for me to lock my character's shape when applying a Puppeteer Pose from another character, I now just load the P-Pose and load my saved characters from this script with only the shape changing, not the pose itself!
    It's usually a pain in the backside to selectively unlock shapes in order to undo certain morphs from loading along with the P-Poses, I mean this is an aptly named little script as it is indeed turning out to be my favourite!
    Would be nice to give this a spin but no matter what I do I cannot get the script to even run
    Post edited by Platnumk on
    edited December 2024
    @Zev0
    This product still has a bug... when applying Shaping Preset.
    If there're exsiting values on the morph properties, when applying the saved Preset, the values will be added (stacked) to the properties even if I check the option Zero Shape before Applying...
    https://mega.nz/file/nbwxGSqC#H12kP3kg54ZobPWqzBU0TBOd1Au1GUeAvzDjaMxN5D4
    Edit: However, some morphs have this issue (from some vendors in this store...), some don't (from Daz Originals)... and I check the settings in Parameter Settings, there's no difference. Strange.
    Sorry for late reply, Didn't get notifications again....Will look into all of these. My partner who handles the core scripting has gone missing for over 2 weeks now so urgently awaiting a response from him regarding some minor issues being reported, which is delying the update...
    Thank you very much ! No rush ~ pls take your time.
    Are they doing OK health wise?
    As health seems to be a common issue with our lot as of late... so I hope they are well!
    No response yet on discord....
  • jmucchiellojmucchiello Posts: 1,935
    How does this product compare to Dial Fusion G9 Edition?
