Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Thanks Lyoness for your solution and to everybody else who contributed!
As I render linear at gamma 1, not the default Daz 2.2, I go through every texture in a scene and make sure it's set to gamma 1 in the Image Editor.
The gamma you use for rendering and the gamma of the textures are not related - in principle you still want to correct the colour images for their probable embedded gamma of 2.2 even if you are rendering to gamma 1.
Done that time and again, and I still have to manually edit the gamma value in the texture editor to 1.
This has solved an issue I was having occasionally after edditing textures.
I just checked the Gamma on a custom texture and it was 1, whereas the original was 0; this is good to know. The work around I had was to open and save the image without altering anything, and using the saved image as a custom one, even though I'd not changed it; although I knew the default save was altering something.
This made an interesting read:
http://www.cambridgeincolour.com/tutorials/gamma-correction.htm
