DIM won't install a product...
Hi all. I haven't been here in years, so please forgive me if I'm asking in the wrong place:
I'm having trouble using DIM to install the Daz to Cinema 4D plugin. DIM keeps popping up with "Retry" when I click on install. I was able to find the zip file on my drive and it's in the correct download directory. The Daz to Photoshop Bridge won't install, nor will "Scene Builder" (which I don't care about).
Thank you!
That sounds as if the files are not in fact downloading properly. Are you getting asny error messages? What about if you click the gear icon at top-right to get to the log?
If it is trying to install, these are plug-ins and so will use DIMHelper and require UAC approval (a "Do you want to allow" pop-up) before they can proceed.
Thanks for your reply, Richard. The downloads appear to be fine. I don't get a popup when I click install. Do you know what I can do to get that popup? I'm on a Mac.
Ah, then you need to tell gatekeeper to allow the installer (DIMHelper, not DIM itself) and I think there is an extra step - check https://www.daz3d.com/forums/discussion/16599/the-mac-faq#latest
