Is there a way to eliminate the reflections of Ghost Lights? (Solved)
BlueFingers
I am working on a scene in which I use a ghost light, however the reflection of the ghost light really doesn't work in the image. Is there a way to eliminate the reflection? See image as an example.
Other types of suggestions on how to manage the reflections are welcome too.
Post edited by BlueFingers on
I used a primitive with the "Create Advanced Iray Node Properties"-script from the Daz Default Resources, I didn't know there were more ways to create a Ghost Light with the current version of Iray. If there is a better way, please share
Ah, apologies, I wasn't aware. I used the script to turn the primitive in to an advanced Iray Node and selected the options "Iray visible to primary rays" and "Iray Ghost Light factor", then I turned of the "Iray visible to primary rays" in the parameter tab for the primitive.
Creating a "Ghost Light" - Daz Studio 4.21.1.26+ - Daz 3D Forums did you use the Ghost Light factor to address refelction?
I didn't, but now I do :-)) Thank you so much!! It's not perfect, but I can work with it, and it'll save quite a bit of work in post!
