DSON Problems Installing on Poser Pro 2012
Fauvist
in The Commons
I had to reinstall Poser Pro 2012 and now I can't get DSON to work. I uninstalled it from the computer, then reinstalled it, but when I try to use Genesis I get a message saying DSON was not found. DSON has one of those automatic installers. I know what folder it's going into, but it's a folder with a thousand other things. Is there a file list that I can see for DSON that shows the exact name of the DSON files that are installed, and where they're suppose to go?
Thanks!
Are you using DIM or a stand-alone installer?
I'm using PPro2014-64bit, and AFAIK these are the files/locations that get installed
......./Poser Pro 2014/Runtime/Python/addons/dson
__init__.py
boost_python-vc100-mt-1_50.dll
dzdsonimporter.pyd
DzDSONIO.dll
QtCore4.dll
......./Poser Pro 2014/Runtime/Python/poserScripts/ScriptsMenu/DSON support
Importer Preferences....py
Transfer Active Morphs.py
......./Poser Pro 2014/Runtime/Python/poserScripts/ScriptsMenu/DSON support/Subdivision
Set SubDivision Level 0.py
Set SubDivision Level 1.py
Set SubDivision OFF.py
I tried with the DIM and it wouldn't do anything. So I tried with a manual download and that wouldn't work unless I disabled the installation of the extas that come along with the DSON.
Thank you for this. I'm on a Mac 64bit. These are the files that got installed on my computer. They look similar to yours.
A bit of a longshot, as I do not have a mac; I'm using a pc/win7 combo... When I had dson installed for PPro2012 and PPro2014 (both versions are installed on my system), I didn't work. I had to completely uninstall dson from both versions (there were 2 dson's in my installed programs list) and even manually delete any remnants that had been left, before reinstalling dson for just Ppro2014. I don't know if something similar might have happened here...
What is the folder location that you are trying to save DSON to?
The previous copy of DSON gets uninstalled, before I try to install the new one.
The folder location I'm trying to save DSON to is HARDDRIVE - APPLICATIONS - POSER PRO 2012.
The necessary content is installed in my Runtime.
I'll attach the message I get from Poser when I try to load Genesis into the scene.
If you can't install with DIM (as DIM most probably thinks it's already installed, have you tried to first uninstall with DIM?
Yes, I uninstalled with DIM.
DSON worked with this Poser Pro 2012 before I uninstalled Poser. After I reinstalled Poser Pro 2012, DSON wouldn't work.
Yes, but you might need to uninstall DSON from DIM to get it correctly back in again.
I did that.
After reinstalling Poser and any SR's?
What is "SR"?
Service Release
All I installed was Poser. Where do I get the service release?
http://my.smithmicro.com/poser-pro-2012-updates.html
Thank you. I'll install that.
