DSON Problems Installing on Poser Pro 2012
FauvistFauvist Posts: 2,290
I had to reinstall Poser Pro 2012 and now I can't get DSON to work.  I uninstalled it from the computer, then reinstalled it, but when I try to use Genesis I get a message saying DSON was not found.  DSON has one of those automatic installers.  I know what folder it's going into, but it's a folder with a thousand other things.  Is there a file list that I can see for DSON that shows the exact name of the DSON files that are installed, and where they're suppose to go?
Thanks!
    Are you using DIM or a stand-alone installer?
  • glaseyeglaseye Posts: 1,312
    I'm using PPro2014-64bit, and AFAIK these are the files/locations that get installed
    ......./Poser Pro 2014/Runtime/Python/addons/dson
    __init__.py
    boost_python-vc100-mt-1_50.dll
    dzdsonimporter.pyd
    DzDSONIO.dll
    QtCore4.dll
    ......./Poser Pro 2014/Runtime/Python/poserScripts/ScriptsMenu/DSON support
    Importer Preferences....py
    Transfer Active Morphs.py
    ......./Poser Pro 2014/Runtime/Python/poserScripts/ScriptsMenu/DSON support/Subdivision
    Set SubDivision Level 0.py
    Set SubDivision Level 1.py
    Set SubDivision OFF.py
  • FauvistFauvist Posts: 2,290
    I tried with the DIM and it wouldn't do anything.  So I tried with a manual download and that wouldn't work unless I disabled the installation of the extas that come along with the DSON.
    __init__.py
    dzdsonimporter.pyd
    DzDSONIO.dll
    QtCore4.dll
    Thank you for this.  I'm on a Mac 64bit.  These are the files that got installed on my computer.  They look similar to yours.
    710 x 610 - 128K
    A bit of a longshot, as I do not have a mac; I'm using a pc/win7 combo... When I had dson installed for PPro2012 and PPro2014 (both versions are installed on my system), I didn't work. I had to completely uninstall dson from both versions (there were 2 dson's in my installed programs list) and even manually delete any remnants that had been left, before reinstalling dson for just Ppro2014. I don't know if something similar might have happened here...
  • frank0314frank0314 Posts: 15,098
    What is the folder location that you are trying to save DSON to?
    The previous copy of DSON gets uninstalled, before I try to install the new one.
    The folder location I'm trying to save DSON to is HARDDRIVE - APPLICATIONS - POSER PRO 2012.
    The necessary content is installed in my Runtime.
    I'll attach the message I get from Poser when I try to load Genesis into the scene.
    400 x 305 - 26K
  • TotteTotte Posts: 15,100
    If you can't install with DIM (as DIM most probably thinks it's already installed, have you tried to first uninstall with DIM?
    Yes, I uninstalled with DIM.
    DSON worked with this Poser Pro 2012 before I uninstalled Poser.  After I reinstalled Poser Pro 2012, DSON wouldn't work.
    Yes, but you might need to uninstall DSON from DIM to get it correctly back in again.
    I did that.
    After reinstalling Poser and any SR's?
    What is "SR"?
    Service Release
    All I installed was Poser.  Where do I get the service release?
    Thank you.  I'll install that.
