Daz AI Studio - Official Beta Launch!
1235»
  • Byrdie said:
    Not a Premium or Daz+ member and using the free version of Daz AI Studio. I see that the Genesis models are now all disabled, does this mean they will be for paid/Premium subscribers only or is something else going on like maybe a borked update or whatever? Was playing around with it last night and some things worked while others that used to didn't. frown
    I pay for the premium version of Daz AI Studio (and I am a Daz+ member), but the Genesis models are all currently disabled for me too.
  • caravellecaravelle Posts: 2,699
    +1!
  • I just subscribed. I wish I had looked at this first. The Genesis models are disabled, when I try to generate any prompt it fills the progress bar, spins & then aborts. It takes a long time to do so. How are yo utaking subscriptions for this when it doesn't work? Please provide some information as to what is happening & when it will be fixed. Thanks
  • It honestly doesn't listen to prompts very well, plus the images always look distorted.
  • barbultbarbult Posts: 26,513
    It's broken again. It just spins forever and never finishes.
  • As I said in the other thread, it worked for me when I tried just now.
    edited January 2025
    Thanks for testing and replying. I don't know which forum thread is the correct place to post messages like this. This one seemed "official", but then I stumbled on the other one that seemed more active.
    It seems to be a "seed" problem. I entered a long string of random number as the string. If the list of numbers is too long it reports "An error occurred".  If the list of numbers is long, but not long enough to trigger the error, it seems to run to 100% but "never" show an image. I waited minutes. Is there any documentation about how to use the seed field? Evidently I am doing it wrong. I am on the free version.
    1221 x 1315 - 101K
    Post edited by barbult on
  • Richard HaseltineRichard Haseltine Posts: 109,294
    edited January 2025
    If you click the "seed" icon oin a generated image (it actually looks like a couple of nuts) it will populate the Seed field with the value used (to start a pseudo-random number generator that produces the initial cloud of dots that the system then refines statistically to align with images using the prompt words, to my rough understanding). Using the same seed and prompt will give the same result, but if you vary the prompt slightly with the same seed it should give an image that is quite close to the original generation but inpcorating the changes made to the prompt. In the attachment I added rainy to the prompt for the upper image, using the same seed - it has kept the layout broadly the same, though i suspect rainy had a bit too broad an effect to really  show continuity.
    538 x 725 - 93K
    Thanks for the explanation. So I gues it is not just a text entry field where I can enter anything I want.
    edited January 2025
    I tried it again, clicking the "seeds" icon. I can't tell if it really works. The first time it changed the cat to orange, like I asked, and it is still in a room with a window, but the cat pose is quite different and the cat is very large. In the next one, it gave me a blue chair like I asked, but the room with the window is completely gone. They just look like completely independent image generations to me. Maybe the prompt is too  trivial.
    293 x 822 - 48K
  • I think it works best if the new prompt is a refinement of the old - which I tend to assume a bit added at the end, though that may not be true. However, the process is pretty sensitive to initial conditions so I don't know how well this will work in general - my success rate with AI in general is pretty low.
  • Just wondering about the characters... Are they supposed to be disabled? If not, is it being looked at?
    247 x 622 - 45K
    People keep asking, but I never see an answer. Maybe I missed it.
  • Are the Devs even watching this thread?
  • I have a better idea, which is a mix of my idea plus others. You have the ability to make video with the characters in the program. How about make an AI scriptwriter, where you can put in a script, and the AI uses it with your creations to make a video of the characters in Daz, doing what you want? It'd be iClone out of the park if it were that easy, and create 3D movies with just ideas.
  • linvanchenelinvanchene Posts: 1,386
    edited May 2025
    Some impressions after more than a year:
    It is  a pity that this project did not receive further updates.
    - There is still a lack of trusted sources who provide checkpoints.
    - There is still a lack of trusted sources who provide LoRA to generate conistent faces for characters.
    - The basic idea to train dedicated checkpoints for specific themes like fantasy, science fiction, cyberpunk, steampunk etc. is still valid.
    - What could be a viable base model?
    The situation remains chaotic. New base models for image and video generation are released and updated frequently.
    The "community" seems equally split between them.
    Few may have access to a local GPU who has more than 24GB VRAM, many may rely on 16GB cards or lower - this limits the viable options for local use.
    From that point of view work on Daz AI Studio may be on hold until a clear path forward emerges...?
    Post edited by linvanchene on
  • yuyu.atemyuyu.atem Posts: 474
    Hi! I can't find Daz AI Studio anymore: I usually accessed it by 3D Software -> Daz AI Studio, but now, I don't find it. Isn't it at the same place as before?
    Thank you in advance!
  • LeanaLeana Posts: 12,944
    Looks like you missed the announcement: Daz AI Studio shut down at the end of May.
    edited June 2025
    Oh, no, I didn't see that! crying It's too bad! I hope they will find a new  partner to open it again...
    Thank you very much for your answer, anyway!
    Post edited by yuyu.atem on
  • foleyprofoleypro Posts: 485
    So since we didnt stop using but DAZ quit, will you all let us use the software as is and let us have the 8 images and more then just 1024x1024, I betatest topax Gigapixel so I dont need sizes I can do any size but since you all shut down but I can stil access the software would be nice to use still...When I joined we had different humans we could use, then you shut that down but I kept paying,
    What software? The blog entry says:
    This change comes as a result of our current partner discontinuing support for the APIs that power key features of the service.
    so this isn't a self-contained application that Daz can share or enable.
  • Instead of focusing on AI-Art, why not use LLM AI to AUTOMATE some of the Studio Workflows? As in, you describe a scene the same as you would for image generation, but INSTEAD it goes through your CONTENT LIBRARY and tries to BUILD A SCENE to your specifications... it could even suggest products from the store if you're missing the needed assets.
  • wolf359wolf359 Posts: 3,943
    edited June 2025
    We were teased an AI system like that  over 2 years ago
    but it never materialized.frown
    Post edited by wolf359 on
  • richardandtracyrichardandtracy Posts: 7,419
    Feels like 'Implement, Ignore, implode'. Same happened with NFT's (but with rather more cause in that case, I feel).
    Regards,
    Richard
  • rigomrtsfxrigomrtsfx Posts: 103
    what happen to studio ai
    this is the first time hearing this one
    i am still using daz studio
    The two were not related, and on AI Studio see https://www.daz3d.com/blog/ai-studio-important-update
