• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic on Linux
mikael-aronssonmikael-aronsson Posts: 599
October 2024 in Blender Discussion
Hi!
Has anyone tried using DAZ exported stuff on Blender running on Linux (path related issues upper/lower case and so on, it looks like this has not been tested for some time) ?
I am not running DS on Wine, I am running DS on a Windows 10 machine, but after exporting the stuff to Blender(Win) I want to use the exported content on Blender(Linux), do I have  to copy the import_daz_scanned_absolute_paths.json to the Linux machine for this to work ? so am not going to export anything on the Linux machine, this is all done on the Windows machine, all the exported content is then copied to the Linux machine.
  • PadonePadone Posts: 4,083
    October 2024
    Once you convert to blender there's no reference to the daz scene or library anymore, apart the textures if you didn't make them local.
  • mikael-aronssonmikael-aronsson Posts: 599
    October 2024 edited October 2024
    I know, the question is if there will be any case related problems, Windows don't [care] about upper lower case while Linux does.
    Lets say there is a texture called MyTexture.png and there is a reference to it from some other file that use mytexture.png as the reference, works fine on Windows
    Post edited by Richard Haseltine on October 2024
    October 2024
    In diffeomorphic there's an option in the global settings for "case sensitive paths", to be used under linux.
  • brainmuffinbrainmuffin Posts: 1,282
    October 2024
    I have been running Blender on Linux for quite some time, but my DAZ export was coming from a Mac
  • ThomasLarssonThomasLarsson Posts: 99
    I did use a Linux computer some years ago, but it broke down and now I don't have access to Linux myself, so I'm not sure how much works. However, there has been users on Linux who run DS under Wine and importing files into Blender with diffeo.
    The main problem is case-sensitivity. Not just that the file paths depend on case, but that several case-sensitive paths can correspond to a single case-insensitive one. That situation may be a problem for DS under Wine too. To overcome this, you need to scan the entire daz database with the Scan Absolute Paths button in the Utilties panel, https://bitbucket.org/Diffeomorphic/import_daz/wiki/Utilities. This tool creates a file which associates case-insensitive directories with a list of case-sensitive ones. If the global settings "Case-Sensitive Paths" is enabled, the plugin uses this table to find the right file. But I haven't tested this for quite some time and am unsure if it still works.
    Post edited by ThomasLarsson on October 2024
    October 2024
    Thanks, I will give it a try and see.
    October 2024
    As my Mac died, I now run Studio in WINE (fonts are really, really small). I will have to check this out.
    A silly question, is the absolute path file only used while importing ? or is the file needed on the Linux machine also.
    In my case I import from DAZ running on a Windows machine to Blender (same machine so also windows), all the contents are then copied to another machine running Blender on Linux where I want to use it without any DS involvement.
    As far as I understand from the blogpost the file generated is only used at import from DAZ and is not used after the import has completed, is that correct ?
    Same question about the checkbox "Case-sensitive path", do I need to set that on the Linux machine even if I am never going to actually import on it ?
    Or would it be better to map the DAZ content drive so the Linux machine can access it to import using Blender on the Linux machine instead of copying the imported contents from Blender(Win) to Blender(Linux) ?
    Note: I always use the "Save local textures" to copy the texture files if that makes any difference.
    Hope I did not make that sound too confusing ;)
    Post edited by mikael-aronsson on October 2024
    October 2024
    Unless something has changed, the import needs the DAZ files, but once saved as a Blender file, it does not.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
