Need help with DFS files
2»
  • lilweep said:
    Lilken69 said:
    lilweep said:
    I downloaded the .rar for this freebie, unzipped to new folder, and copy/pasted the contents into a new content directory and everything worked fine.
    There is no file in this product called Cap suit_219086
    Perhaps search your directory to find out where that file is and temporarily remove it, or just ignore the error...
    Since it won't install in my 3rdContentParty file, I added the file in My 3D library and it went threw. I try adding the outfit on my character and i get this huge block saying files are missing.
    So ... did you install it properly by putting the /runtime folder into your directory?
    In other words, do you actually have that directory and those texture files in your 'My 3D library' content library?
    I just downloaded a suit from RenderHub. I install it the same way i try to install DDDark files in my 3rdpartycontent file and it worked. I don't understand why DDDark files doen't work for me. I did everything right
    1211 x 1270 - 633K
    1945 x 524 - 79K
    1957 x 983 - 539K
  • lilweeplilweep Posts: 2,879
    Lilken69 said:
    Yes i did everything right.
    Did you try the obvious thing of actually going to the folder of the missing file and check the file is there?
    Also what files do you claim are missing? In your screenshot the dialog box is too small to read the full file path.
    Yes this is the runtime path. all the files are their
    1210 x 702 - 59K
    1198 x 588 - 37K
    1189 x 657 - 33K
    1245 x 599 - 32K
    1327 x 978 - 113K
    If you look at your file structure vs what the error told you the path shoud be you will see:  you have runtime/runtime/DD Dark... but it should be runtime/DD Dark...
    338 x 75 - 1K
    260 x 155 - 38K
    Omg it worked. Runtime/Runtime was the problem, People and Data also had double path as well. I fixed it. Thank you so much for your help.
    1860 x 1122 - 629K
