[Released] ManFriday’s Figure Converter for Genesis 9 [Commercial]
12345679»
  • drawfleshdrawflesh Posts: 17
    edited July 2024
    Anyone else running into the situation where the script doesn't come up with the second (safe) dialog anymore? I have tried reinstalling it...but that doesn't seem to have any effect. Will try it one more time through DIM, but I hope it is fixed by that.  Never mind, I have 2 external monitors...for some unknown reason the dialog was on the laptop screen, that was closed.....Sigh.
    About error messages I read above:  when converting, I normally only get them when there was an additional 'wearable', like a tail or something to the model.
    Post edited by drawflesh on
  • Necro, but since this is now part of Premier, did you fix the Genesis 3 conversion?
  • I didn't read thru all this but is this tool the same as is in the Premier tier?
    If so will there be a update so the G9 eyes and mouth will also convert? Is it even possible?
    Or if it's any hints to make the eyes fit better? That is the only thing I hate about G9 when creating my own converted game models, is the damned eyes.
    Hoped the sculpt tool worked but it did look like it worked in the Premier promo trailer.
  • Maybe I've missed it in the thread. Does anyone have the Rigging box missing when they open the converter?
  • suffo85suffo85 Posts: 212
    edited February 2025
    @barbult
    I don't own this product but found this thread when doing my own manual conversions with G3 to G8/9, and was looking for an answer to the hand stretching problem.  This thread has expanded a bit since then, and I see you've posted a workaround, which is awesome lol so I'm a bit late to the party but I puzzled the entire issue out and fixed it, at least for my manual conversions.  The problem with G3 is the T pose, the stock clones do not attempt to align with it at all and remain in the A pose.  Just putting G3 into the A pose wasn't enough to outright solve the issue though, I'm speculating because of the differences in the way the shoulders work.  It fixes some of it, but then other parts of the resulting conversion will be warped like the arms.
    The way I solved it was by creating my own clone from scratch and using Blender's shrinkwrap modifier wrapped G9 to G3's T-pose including the weird shoulder geometry.
    Anyway, it's simple to make with a little patience and positioning as long as you're not afraid to mangle G9 a bit in Blender lol.  Essentially it's just adding a shrinkwrap modifier to G9 and then stretching it until you can ensure that when you apply the modifier all of the bodyparts go where they're supposed to, stretching and mangling upper G9 torso is definitely required lol.
    I hope this post can bring about a fix for you guys. yes
    Also I don't mind providing my clones for download, I don't need or want anything for them, I never made them available because I'm not sure if they would violate Daz's copyright since they're essentially still in their original forms, just shrinkwrapped to other Genesis versions and origin poses.
    Edit to add, if you attempt to do this make sure that before you export your final product in Daz Studio (for example, if converting G3 to G9, your final product would be the G9 morphed into whatever character you've converted), make sure you return it to the proper A pose for G9 using the arm bends 45 and -45, and the leg positioning, etc.  Same applies if you're exporting our a G8 morph except the leg bends are a little different then.
    Post edited by suffo85 on
  • ChaosDrgnChaosDrgn Posts: 33
    suffo85 said:
    @barbult
    The problem could be adjusting the rigging to shape. Is the issue when you pose the figure?
  • @suffo85
    I'm curious about this shrinkwrap solution using Blender. What version of Blender is that available? I stopped upgrading Blender around 2.79. I just couldn't deal with the interface in the later versions. Stuff I was used to using I couldn't seem to find where it got moved.
    GRFK DSGN Unlimited said:
    @suffo85
    Uhh, I don't remember what version of Blender I used when I made my clones.  Pretty sure I made those at this time last year and I haven't touched shrinkwrap since lol, you could go look on Blender's site which version was current (stable branch, LTS) during December in 2024.  But shrinkwrap is in the current version, so I probably wouldn't go through all that trouble and just get the most recent LTS.
    If you have any specific questions regarding the process hitting up my private messages is probably the best way to get my attention here.
    If your character isn't warping badly though I'd just use the PA's product to make everything quick and painless.
  • AsuCafeAsuCafe Posts: 279
    I've only just noticed this product (I joined relatively late). I've seen some people say it's already part of Premier. Where do I activate this product? Or can I find the tutorial PDF?
  • nemesis10nemesis10 Posts: 3,881
    edited December 2025
    1. Make sure you have the current version of Daz Studio Alpha 2025
    2. Install the Shape Transfer 2025 from DIM
    3. Open Daz Studio Alpha... load your Genesis 8 for example and the generic Genesis 9 from Genesis 9 Essentials
    4. Select them both and go to Top Menu>Edit>Figure>Shape Transfer
    5. Let it do its magic
    1624 x 1038 - 554K
    Post edited by nemesis10 on
     Thank you! I've been looking for this feature for a long time, and I can't believe I'm only just now learning how to use it.
