Auto-Fit Partially Disabled in a Figure?
This was a weird one (aren't they all?)
Created a new figure/morph for G8F. I saved it as both a Scene and as a Character Preset.
When I load the figure as a Scene file, everything works fine. If I try to load a non-G8F hair or clothing item, Auto Fit appears as it always does.
When I click on the character preset, Daz loads the same figure into the scene... but, if I try to fit any non G8F clothing/hair, the Auto Fit window only gives the first option ("What Figure Was the Item Originally Designed For?"). No matter what I select, the second drop-down menu ("What Type of Item is it?") remains grayed out and unselectable.
I can only assume that there's a setting gone wrong in the character preset but, for the life of me, I have no idea what it could be, or why it would affect the preset and not the scene-loaded figure. If I choose a vanilla G8F and load the character preset onto her (as opposed to loading a new figure into the scene) that figure can also use Auto Fit correctly.
First thought was to check the compatability base for the Character Preset figure, but that's all set to G8F like normal.
(edit: also tried deleting the Character Preset and creating a new one from the Scene file, no luck there either. Saved just fine, loads just fine, same partial Auto-Fit problem)
Post edited by Blando Calrissian on
  • crosswindcrosswind Posts: 10,330
    edited October 2024
    I couldn't reproduce the issue... What's your DS version ?
    Post edited by crosswind on
    Working right now in 4.22.1.110
  • i have DAZ 4.21 Pro and i have similar incompatibilities between G3 clothing and G8 models. i have only discerned that the problem is an inbality to deal with the two different T-Poses, which change for person models between Gen 3 and 8. i have tried numerous times to auto fit Gen3 clothing to Gen8(+) body models. its better on the torso, but sleeves to arms, gloves to hands, pants to legs, and boots to feet dont work. it always attaches the Gen3 clothing to the Gen8 limbs according to the limb arrangement in the Gen3 T-Pose. and they dont envelope the Gen8 limbs but hang, parented, beside them.
    and you are selecting the correct base figure in the AutoFit  dialogue?
    I vaguely remember that I've seen the same issue in some older versions...You can try with the latest version, maybe Public Build firstly.
    That is true, AutoFit gained the ability to handle changes to posing about the time Genesis switched default.
  • Thanks, everyone. I will try to upgrade to 4.23 when I get a chance.
    I've found that if I fit a non-G8F item onto any other character (using the normal Auto-Fit) screen, I can shift it over to my 'broken' G8F custom character simply by selecting the item and then "Fit to" from the menu.
    I still have 4.21.0.5 lying around. The same issue happens there, too. I've never had it happen before with either stock Genesis characters or custom ones.
    Is there anywhere under the hood you might suggest I take a look? The compatability base seems to be fine but perhaps there is another setting that I've overlooked? The only lead I've got at the moment is the fact that Auto-Fit works fine when the character is loaded from "Open File" (i.e., Scene) or as a Scene Subset, but not when clicking on the character.
