Free Cyclide Ritual Earrings For Genesis 2 Female
Elegant pair of Cyclide Ritual Earrings, including a left and right object selection. The (POSER).obj files have been scaled to fit perfectly to the "Genesis 2 Base Female" character upon import, in Daz|Studio 4.x.  To import this file into Daz Studio, select File > Import, and find the "cyclideritual-earring_(POSER).OBJ".  There is one model for the left side, and one for the right.  In the OBJImportOptions dialogue box, select the Poser (1 Unit = 8 Ft) preset option in the "From:" dropdown menu.  Scale should be set to 24384% automatically.  If not, then please enter that value into the Scale field.  Keep the Axis Conversion X=X, Y=Y, and Z=Z, with NO checkboxes in the Invert Direction options.  Be sure Read Groups, UV Coordinates, Surfaces, and Material Library (.mtl) are all checked.  The objects are designed to import in place on a default Genesis 2 Female character, in the default T-Pose position in the scene.  Simply parent the earrings to the character's "head" node, once they are in position.
Download From ShareCG.com
or
Download From Renderosity.com Freestuff
Hope you like them.  I stand behind all of my work, be it free or not.   If you have any problems, or need assistance in using this model, please let me know by replying to this thread, or contacting me at any of the resource locations.
  • MilosGulanMilosGulan Posts: 1,991
    Thank You. That looks really good.
  • Faeryl WomynFaeryl Womyn Posts: 3,774
    Thank you and they look fantastic.
    Just as good as the previous set. And they look great in an Iray render.
    I'm trying to decide if they look better if I give the inner swirly bit a pearl material or plain silver. I've just done a couple of test renders, and it looks good either way.  yes
  • luxxeonluxxeon Posts: 18
    Oh, it sounds great!  Can't wait to see what you've done with them.  Please let me know if you post a render, where I can view it.  Thanks!
  • caravellecaravelle Posts: 2,768
    These earrings are adorable; thank you very much!
