Error warning without scripting error? (Surface renaming)
Pushee-Ri
Strange problem here: I'm trying to rename the G8 Surface "Torso" to G8.1 Surface "Body" (for a Geoshell). The script does what it should (without errors) - but I still get the message "Error: Result of expression fFind[null] is not an object " after the script has finished.
I'm not a great programmer, but I think I understand what's going on in most cases. I have found the snippet that I use for finding / renaming the Surface several times here in the forum ... without reference to the error message. So I must be doing something wrong. Here is the snippet:
var oShape = geoShellOBJ.getObject().getCurrentShape();
var oDZMaterial = oShape.findMaterial('Torso');
if (oDZMaterial) { ... }
The "if" triggers the error warning. I have tried it with everything possible (if (! oDZMaterial) etc. ... but the error message still appears. Strange - and like said before: this is the way others suggested.
Since it is a commercial project, I would like to remove the error message. Does anyone have any tips? Sorry in advance if I am late in getting back to you. I have a lot to do at the moment.
Here the forum threads with the snippets (and without reference to possible error messages):
https://www.daz3d.com/forums/discussion/547276/how-to-change-surface-name-by-using-script-correctly
https://www.daz3d.com/forums/discussion/365736/unable-to-define-surfaces-for-a-geoshell
Additional info:
the script runs “save” (within an empty function), the version is // DAZ Studio version 4.15.0.2 file type DAZ Script
Error: Result of expression fFind[null] is not an object - fFind?
Yes - I just put on a pair of glasses: is “fFind” when using "oShape.findMaterial('Torso')"
Not related to the error, and you haven't stated your end goal, but wanting to rename 'Torso' to 'Body' on a GeoShell suggests you may actually want to be using a 'Surface Selection Set' instead (described in the second half of section 3.5 in the User Guide).
I posted a script that adds the Genesis 8 Legacy set to a Genesis 8.1 GeoShell in the thread Batch process G8 geoshell presets to G8.1 a few years ago that you may want to look at, also related is the script I posted in the thread Geoshell setup script?
Yes, a Geometry Shell is the same mesh as the source, albeit with its own surface settings - you cannot edit its groups or other basic aspects.
@ Omniflux:
Yes, I know your perfect geoshell scripts - they led me to the light during my first steps :)
Of course, I have already tried “Legacy” - which led to errors for me, as I don't have “Legacy” ... i.e. customers without “legacy” will receive the same error message.
The goal of the script is to rename the “Torso” Surfaces of a GF8 Geoshell to “Body” (GF8.1) in order to use the already finished Material Presets (85!) that I have developed for GF8.1. This works perfectly (i.e. I can rename GeoShell Surfaces) ... only at the end - when the script is finished - I get the error.
@ Richard Haseltine
As mentioned in the thread opener and just said again: the script renames a GF8 Geoshell Surface “Torso” to “Body” without any problems and I can assign material presets, property presets etc. that were developed for GF8.1 (“Body”) Geoshells. Only at the end - i.e. when the renaming has been successful - the error message appears ... although the script runs through.
Looks like I'll have to live with the error (or error message) for the time being and explain to my customers why it's occurring. It's a bit more paperwork and explanation work ... but my customers are already used to that from me ;-)
Many thanks for your comments :)
