Saving a morph asset
Hi All, I've encountered a strange issue.    I have a couple of morphs saved on a figure and I've created a controller morph that dials in the first morph when I slide the controller to 100 and dials in the second morph when I dial to -100.  Works like a charm.
The problem I ahve is I can't seem to save it.   I've triend Save As > Support Asset > Morph asset and saved both the controller and the two morphs being controlled.    While it didn save the morph it didnt save the properities so the slider does nothing.    I tried again thinking I'd fogotten to save one of the morphs but that didn't work.     I then tried resaving the complete figure.  That hasn't worked either.
I'm stumped...
Help!
  • I think rather than proeprties you mean the links, formulae. If you check in the Property Hierarchy to find the cotnroller, then drill down to get its subcomponents and find their attributes what the links set to save with? Did you save that after creating the links?
  • LZYLZY Posts: 36
    Thank you Richard as always.    The Controller's links were set to save with the morphs it was controlling, I changed that and it seems now to be saving as I expected...
