Making Sliders/Dials for Clothes Morphs - How? (Am Total Eejit, Solved!)
tsroemitsroemi Posts: 3,527
This PA, breeze, creates lovely movement morphs for their clothes (example here https://www.daz3d.com/dforce-brz-sailor-uniform-and-poses-for-genesis-9), is there some way to create sliders/dials from these? Meaning, I would love to be able to regulate how much of a certain morph to dial in. Is there an established workflow to do this?
Thanks for helping!
(Edited for clarity)
Post edited by tsroemi on
  • Pose the figure and adjust the clothes (simulation, in DS or soemthing like Marvellous Designer, or direct sclupting or a mix), load as a morph with the pose still applied and Reverse Deformations on, save morph and pose.
  • tsroemitsroemi Posts: 3,527
    Hi Richard, thanks for the reply, I think I'm being a bit daft right now: How is this gonna turn the morph into a slider/dial? The morph is already there, right, because the PA made it for their clothes; do you mean I need to save it out again? And this would somehow make it have a dial for adjusting the value when loaded back in? But how?
    All I want really is to be able to dial down the movement morphs that the PA made for their clothes after I've applied them, see, because they're a bit much at times. Gosh, I feel like such an idiot, can't even explain this properly, sorry ... blush
  • crosswindcrosswind Posts: 9,697
    I still don't understand what you want. Those "movement morphs" were tailor-made for each Pose accordingly. Since you've already dialed the morph for a Pose, why do you need to dial it down ? Because you want to make a subtle change... ? If so, just reduce the value... that doesn't work ?
    You don't need to create new morphs at all, IMHO ~~
    2560 x 1392 - 763K
    edited September 2024
    O - M - G, can I really be this stupid?! With the BRZ dress that I'm currently fumbling around with, I thought I'd looked everywhere in parameters and couldn't find the morphs in there, so I simply assumed there hadn't been any dials created for them. I'll go check this immediately. Thanks so much in advance!
    Edit: Yes, they're there! I didn't see them before because I only checked in 'currently used', and since they have abbreviated non-descript names like B1G9 or something, I just skipped over them, thinking these were some technical morphs for pose adjustment.
    Again, thank you so much! And sorry for being such a bother out of sheer stupidity (also should maybe sleep a little more, duh ...). blush
    No problem ! Haha ~ Enjoy and take your time ! laugh
