Making Sliders/Dials for Clothes Morphs - How? (Am Total Eejit, Solved!)
tsroemi
This PA, breeze, creates lovely movement morphs for their clothes (example here https://www.daz3d.com/dforce-brz-sailor-uniform-and-poses-for-genesis-9), is there some way to create sliders/dials from these? Meaning, I would love to be able to regulate how much of a certain morph to dial in. Is there an established workflow to do this?
Thanks for helping!
(Edited for clarity)
Post edited by tsroemi on
Pose the figure and adjust the clothes (simulation, in DS or soemthing like Marvellous Designer, or direct sclupting or a mix), load as a morph with the pose still applied and Reverse Deformations on, save morph and pose.
Hi Richard, thanks for the reply, I think I'm being a bit daft right now: How is this gonna turn the morph into a slider/dial? The morph is already there, right, because the PA made it for their clothes; do you mean I need to save it out again? And this would somehow make it have a dial for adjusting the value when loaded back in? But how?
All I want really is to be able to dial down the movement morphs that the PA made for their clothes after I've applied them, see, because they're a bit much at times. Gosh, I feel like such an idiot, can't even explain this properly, sorry ...
I still don't understand what you want. Those "movement morphs" were tailor-made for each Pose accordingly. Since you've already dialed the morph for a Pose, why do you need to dial it down ? Because you want to make a subtle change... ? If so, just reduce the value... that doesn't work ?
You don't need to create new morphs at all, IMHO ~~
O - M - G, can I really be this stupid?! With the BRZ dress that I'm currently fumbling around with, I thought I'd looked everywhere in parameters and couldn't find the morphs in there, so I simply assumed there hadn't been any dials created for them. I'll go check this immediately. Thanks so much in advance!
Edit: Yes, they're there! I didn't see them before because I only checked in 'currently used', and since they have abbreviated non-descript names like B1G9 or something, I just skipped over them, thinking these were some technical morphs for pose adjustment.
Again, thank you so much! And sorry for being such a bother out of sheer stupidity (also should maybe sleep a little more, duh ...).
No problem ! Haha ~ Enjoy and take your time !
