Why do the new, "Morphing Gemstones" not respond at all to a Daz spotlight?
Morphing Gems, Shaders and IMM Brushes
https://www.daz3d.com/morphing-gems-shaders-and-imm-brushes
They respond to ambient light from a HDRI but when set to scene only they remain black when other light sources are used.
Thanks in advance for any help on this.
  • felisfelis Posts: 6,147
    It does respond to light. But in order to light a gem, you need several lightsources, or if only one some surrounding that has a high gloss (reflects).
    A gem is essentially a multifacetet reflector, so if no light  no reflection.
  • crosswindcrosswind Posts: 9,743
    edited September 2024
    Without a Dome HDRI, you at least need an interior e.g a sphere or a cube primitive for bouncing the light, as well as one spotlight with big values set in Spread Angle, Height and Lumen to bring good refraction effect to the gems ~~
    It's a sort of "simulating" a Dome lighting ~
    2560 x 1392 - 2M
    Post edited by crosswind on
