Adding to Cart…
You can hide the unwanted sections using the buttons in the Parameters pane, if copying materials doesn't work or isn't what is needed.
actually that process is pretty standard. I used to save seperate presets, but DAZ suggested I change to full HMATS for applying the gen textures.
As for shells...you will have to select the shell in the scene and then in the parameters tab turn off the visibility on the extra graft parts
Thanks for the response Rawart. Does the rentacle have a a geogaph? I'm a bit confused.
Okay Rawart. I gotcha. Worked great. Thanks.
Soory, I'm a novice with graphic art and Daz 3d. Love the figure but the head tentacles have turned white and I can't seem to be able to change their color. Help!
Ratadan, try the suggestion that Rawart gave me above. It worked for me.
You will likely have to reapply the textures...it seems like the geoshell on the tentacles has nothing applied to it...so select the shell and apply the pattern you like or you can turn the shell off if you dont want anythng there
