[Released] Bone Minion for DAZ Horse 3 Poses [Commercial]
RiverSoft Art
Quickly expand your library of poses for DAZ Horse 2, LoREZ Horse 2, and HiveWire Horse! With Bone Minion, you can directly use poses for DAZ Horse 3 for other Horse figures. Your Bone Minion will do the hard work for you by acting as a bone "catcher" for a pose and then transferring (and converting if necessary) the pose to its parent DAZ Horse 2, LoREZ Horse 2, or HiveWire Horse.* Simply load the Bone Minion on your DAZ Horse 2, LoREZ Horse 2, or HiveWire Horse, select the Bone Minion, and start applying poses!
- On the fly conversion of DAZ Horse 3 poses to DAZ Horse 2
- On the fly conversion of DAZ Horse 3 poses to LoREZ Horse 2
- On the fly conversion of DAZ Horse 3 poses to HiveWire Horse
- Works with DAZ Horse 3 full poses, partial poses*, hierarchical poses**, Horse and Rider hierarchical poses***, and even AniBlocks!
- Automatically applies full poses when they are loaded*
- Supports pose properties (using the Create Heavyweight Bone Minion script)
Note that converted poses (and especially props if they are hierarchical poses) may not be perfect and may require tweaking. Facial Bones (i.e., expressions) except for the eyes are not transferred.
* Any pose that sets the hip of the Bone Minion will be automatically converted on the fly and applied to the target figure. The Apply Changes script can be used to transfer any pose (including partial poses) on the Bone Minion to its target figure.
** Hierarchical poses with props require the props loaded on both the Bone Minion and the target figure. The prop will be properly rotated for the pose but may need to be manually translated to the correct location. DAZ Horse 3 has different bone names than other Horse figures. You will need to manually move the prop to the correct bone on the Target Figure.
*** For Horse and Rider Poses, you must have the correct figure Bone Minion product installed (i.e., if the hierarchical pose is for DAZ Horse 3 and Genesis 9, you must have the DAZ Horse 3 Bone Minion and the Genesis 9 Bone Minion), the bone minions must set up as the hierarchical pose expects (e.g., if the Genesis 9 is supposed to be on the Hip bone of the DAZ Horse 3, the G9 Bone Minion must be on the Hip bone of the DAZ Horse 3 Bone Minion), and the Target Figure of the Figure Bone Minion must be set to your Target Figure.
Bone Minion Tutorial
Horse and Rider Bone Minion Tutorial
Horse Skeleton Model in Main Promo is by Diego Luján García (Creative Commons Attribution) and is available at https://skfb.ly/6nYOS. No changes were made.
Looks awesome!
Going in my cart as soon as you put it out there.
Quick question: will there be a similar bone minion sets for the dragons?
Thanks for the support!
I've considered it. It might happen.
Thank you for this! https://www.daz3d.com/bone-minion-for-daz-horse-3-poses
What a wonderful surprise.
Mary
You're very welcome!
I hope you enjoy it.
