Looking for a particular Peggy Carter-style hair
in The Commons
I'm looking for a hair product that matches the specific hairstyle in the attached images as closely as possible.
Zarah Hair looks the closest from what I've seen, but unless it has the right kind of morphs, it's not long enough, lacks volume, and covers the ears.
You could mix https://www.daz3d.com/sheridan-hair and https://www.daz3d.com/yvette-hair-for-genesis-3-8-female-s to get this look, maybe? Since they're both by April from around the same time frame, the textures should match up. You can load both hairs into the scene and use the geometry tool to delete the parts you don't want, if they don't already have surfaces assigned. To delete a chunk of hair, open geometry tool, select a couple facets on the part you want to go away, use the right-click menu and "select connected" and then right-click menu again to "geometry edit - delete selected" (not sure of the exact name in the menu, but it's something like that)
Maybe this, it has a number of morphs so it can be tweaked in different ways:
https://www.mankahoo.com/index.php?l=product_detail&p=235
Thanks for the help, I'll explore these options.
