Genesis 9 and autofit
Choppski
in The Commons
I am assuming that we just use the template for bodysuit for most products like beards, body hair and clothes? It seems to work, but I am not used to that language
I just used None for hair and the one or two that I tried seemed to work fine. But if you want to try using the bodysuit one, let me know how it works out.
I tried the bodysuit tight on cc beard boss and on dain whiskers. Not only does it work, but to my utter surprise expression morphs work. Often facial hair will "fit" but you can't use any face morphs. So I am pleasantly surprised.
does anyone know how to fix this? this is Mia G9 and boots from Night Queen G8F. i have this with most G8F footware.
has anyone had the issue with skirts and dresses having a 'male bulge' even when the 'male bugle' is sclaed to zero? i even tried turning off parameters and reducing it to -100% and it still showed up.
For converting high heels from G8 to G9, pls check the tutorial in here: https://www.daz3d.com/forums/discussion/comment/8405681/#Comment_8405681
It'll be much earsier to conver Boots with "low heels"... comparing to converting "high heels" shoes.
On the converted skirts and dresses ? the "bulge" looks like a triangle shape or something like that ?
The boots are intended to be used with the feet hidden, or possibly with a morph applied to the feet to make them fit.
These boots are pretty simple, there's neither auto-hide, nor feet morph but just pose controls.
