• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic import. Can't remove glossy from face (SOLVED)
PortlandPortland Posts: 12
August 2024 edited August 2024 in Blender Discussion
I'm having a bit of a problem removing shiny/glossy from the face. I found the "face" texture, played around with the dual-lobe, roughness, and some other settings. Nothing seems to work. When previewing just the material with Blender material preview, the glossyness seems disapear (which is what I want). But during actual rendering, the glossines on the face seems to be back (but just on the face texture itself). Other skin settings like "torso" texture seems to work just fine (i.e. I could remove the glossiness). I'm pretty sure it's not the lighting. Any advice where else to look/change ? Thanks. I'm using Blender 4.1 Cycles.
Post edited by Portland on August 2024
  • PadonePadone Posts: 4,044
    August 2024
    It could be a shell, if so there's separate parameters in the shell material.
  • PortlandPortland Posts: 12
    August 2024
    I think I solved it. Just commenting for future reference in case I forgot. It's the clamp on "multiply add" node to IOR "Dual Lobe" node. I did play with other values. But checking the clamp checkbox seems to work best. It's like turning the light on and off.
    960 x 453 - 86K
    August 2024
    That way you turn off the fresnel effect, because clamp sets ior = 1.0 that's no fresnel. Setting the Fac = 0 in the dual lobe should do the same.
    August 2024
    I tried your method. Removed the clamp and set fac=0 in dual lobe. That didn't work (i.e. didn't remove the strong gloss at all). But you're right. Just checking the clamp somehow made the texture flat. I played with the multiplier (change it from 1.050) and value '2' seems to give me the best result.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
