Hologram Shader for IRAY?
I really want this shader set: http://www.daz3d.com/wireframe-and-hologram-shaders
It's in my cart but I have this feeling it won't work with IRAY. I have completely switched to IRAY and don't want to purchase anything that isn't compatible.
Anyone know if these two play nice together?
  • ScavengerScavenger Posts: 2,676
    This won't answer your question regarding that product, but I've done a little bits with holograms by just using the maps from them in the uber shader and putting the same diffuse maps in the emitter map slots to have them light up.
  • ToborTobor Posts: 2,300
    No, it's not compatible with Iray, as it uses the AoA Advanced Ambient Lights set -- which I have, but don't use because I've also gone (almost) 100% Iray.
    What this set does have, though, are the grid-like wireframe textures, which is the real work involved. You could probably get them to work in the Iray emissive shader, as Scavenger notes. Iray is capable of this look, but you'll have to do the tweaks.
  • ShawnBoothShawnBooth Posts: 465
    Thanks guys. Super appreciated.
