DForce messing up on some wear items
VolvoB10MVolvoB10M Posts: 135
edited August 2024 in Daz Studio Discussion
I am trying to set dforce on  as it splays out in the natural position which looks unrealistic but every time I set dforce this happens, it happened with one other in the past but with this it is newer and there is no way around getting this to work because of it splaying out so far and it happens every single time.
How do I get it to not do this?
Edit: "Some content is not available because of your browser's security settings" message when posting and a section of text has gone missing, I can't mention product names?
Post edited by VolvoB10M on
  • felisfelis Posts: 6,466
    edited August 2024
    Your picture is showing an "explossion".
    That can happen if the mesh is too dense (are there coming warnings of spring voliation before the actual simulation starts), are building up more energy that it can distribute or if there is intersecting, e.g. an arm goign through the body and trapping the clothing.
    How are you simulating, current frame or timeline? What does your pose look like?
    Post edited by felis on
  • VolvoB10MVolvoB10M Posts: 135
    edited August 2024
    The pose is nearly default but with a more natural stand, it is not animated so I am only rendering stills, I didn't get any error messages when I started DForce
    So only a suttle pose.
    Which clothing item is it?
    Does the character have hair, or other objects that couls interfere with the simulation?
    Clothing is skirt and shirt of 89632, figure is 57617, hair is 90215,
  • Clothing https://www.daz3d.com/dforce-su-japan-school-uniform-suit-for-genesis-8-81-and-9
    Character https://www.daz3d.com/danae-hd-for-genesis-8-female
    Hair https://www.daz3d.com/hs-elisha-high-ponytail-for-genesis-9-81-and-8-females
    Are you using the Genesis 8 version of the outfit - it has support for 8 and 9? Is the hair intersecting with the outfit in the starting pose (the memorised pose or the first pose on the Timeline, depending on settings)?
    The version used was the Gen 8 version and I got no incompatability message. I don't know if there is intersecting hair as it flares off, is there a way to set it to ignore material channels?
    Just hide the hair during simulation.
    I have had to try and do reinstallations on software packages to make other packages stop crashing when rendering but now several wardrobe items no longer show up that are G8 compatible when a G8 is selected, it was just a few before but now the ones mentioned above no longer compatible with G8. They appear in the menu without any selected but if G8 character is selected they just disappear so I cannot have them relevence the group together.
    With G8 selected in Scne tab, click the burgermenu (3 bars in the corner) and Edit > Scene Identification.
    What comptability does it list?
    It shows "Genesis8Female" under node name
    It is Comptability Base there is relevant for matching clothes etc.
    What does that say?
  • crosswindcrosswind Posts: 10,101
    Check what's shown in the list of Compatibilities ?
    And, with Edit Metadata with the product, in Content DB Editor, can you see the data of Compatibilities under the user-facing file(s) ?
    2560 x 1392 - 487K
    2560 x 1392 - 376K
    When I have a G8F character selected, that box just shows "Female". I can't select the missing wardrobe items to see what they are under G8F.
