Adding to Cart…
Deepsea's horse fix may have saved DH3 for me. Hopefully, he'll continue. I wish @Linday would make a luxuriant mane/tail/fetlock that rivals CWRW's brushes.
Ok...so...here we go.
I will work on getting a comparison put together.
Thanks, that's really helpful! Doesn't sound too good though, unfortunately. Why would I want what is basically just a morph (with some very limited textures) which prevents me from doing any further morphing? That doesn't make sense to me at all. Huh, would it maybe be possible to split the head morph off with something like Pose Splitter and insert it into Horse 3 proper? I'm not very clever with operations like that myself, but maybe somebody else here knows? Otherwise, it rather sounds like a pass to me, sadly. The head is really very pretty, but ...
Edit: I'm seeing in the file list that the Deepsea morphs are in Horse 3's normal morph folders in data, so - am I misunderstanding something here? It looks to me like I could just dial in the Deepsea horse's head morphs and then add whatever variations I want from my other Horse 3 morphs, from DA's package for example. Melissa, did you maybe mean that the Deepsea horse itself just doesn't come with an additional body morph? That would make sense to me, and I wouldn't really mind that much, since I could use the other morphs for that. Am I getting it right this time? Sorry for being a bit daft today
It doesn't come with a body morph. When you dial in the shape, it's the head only. However...all of my DH3 body morphs include the head as well...so they will not work with DeepSea's head morph unless you like the look of both of them together (you won't). I'm not sure if the newly released DH3 shapes separate head from body. I only have the thoroughbred and standardbred. I'm not spending any more money on DH3 to find out because everything about this model just keeps disappointing me. Having enough shapes is only part of the equation. You need the skin and hair variety to go with it.
I'd expect that the strand-based hair would take shaders, like Colorworks or whatever.
@MelissaGT, I see now what you mean, one cannot combine it with any of the other pre-made shapes. Since I've only bought the DA Morph pack, not the shapes (https://www.daz3d.com/da-ultimate-morph-pack-for-daz-horse-3), and I don't like the Thoroughbred that much, I guess I'd be okay with that. I've checked the DA morphs in the file list, and these really do only include morphs for single body or head areas, so they should be useable along with the Deepsea morph.
I understand your general disappointment, though. I was expecting something much more - I dunno, advanced maybe as well. Which, clearly, Horse 3 isn't, from all I've read here. Still, I do like the extra figures one can make with Horse 3, like the reindeer and Sleipnir, and Pegasus, and now this pretty lil one.
Here is a quick comparison of the new head moprh and color next to Harry. I tried to find the closest approximation of coat color for Harry. This is the Grulla Dun coat along with the Fresian morph (click for bigger size) -
Thanks, very nice renders also! Okay, the Hivewire horse is still in a league of its own, absolutely.
Oof! Thanks for saving me money. Is it a camel, giraffe, or mule? What's up with his tongue?
That's not his tongue...it's a coloration on the lip texture.
I have decided that all-in-all, the Daz Horse 3 looks more like an army mule than anything ;) And those hooves? Wow, just ALL KINDS OF WRONG.
It has potential, but it needs work.
An update for DA Wild Style in DIM today (well, yesterday really, but I didn't launch DIM yesterday. Readme says):
2023-07-19 Updated to reflect the changes in Daz Horse 3
That's about the file name changes in Horse 3 itself that made Wild Style throw off errors and not be able to find required items, I think.
What specifically is wrong with his front hooves/pasterns?
The front hooves aren't too bad, but the back hooves just look wrong to me. Like they're cut off half way down the hoof or something. Plus, I think both sets of hooves need to be longer on the fronts with a shallower angle. Just my two cents ;). And maybe it's just me, but neither set of hooves looks quite large enough for the size of the horse.
Here this book is around 300 pages and should help.
You suggest that the conformation of the horse "Plus, I think both sets of hooves need to be longer blah blah blah" should be altered in accordance with what you perceive as correct or incorrect or how it looks to you? The back hooves need work the front hooves/pasterns are fine as is. The length of a horses toe/foot is variable with some choices being better than others for the animal (i.e., long toes on some show horses vs short feet on race horses...long toes/feet lose and are usually detrimental to the animal as in Saddlebreds/Tennessee Walkers because along with the longer toes/feet go a change in the angle of that hoof to his pastern and affect the breaking over of his pastern when he moves and also forces the weight bearing to the outer walls of the hoof) Humans like them because the poor horse picks his feet up really really high and looks flashy - well yeah you just threw his legs off balance.
Bigger feet are better when proportional to the animal, his are fine, shorter toes/feet are usually better. The entire weight of his body is supported on those 4 hooves. This model does have some leg problems but they're not his hooves (front ones at least).
The "horse" problem in 3d is that modellers don't know what constitutes good conformation or a good horse overall. They grab a picture and model to it not even knowing if they're modelling a good or not so good horse. Many many show horse champions are not good horses.
But you're absolutely correct in being concerned with his hoofs. No hoof, no horse.
Hoof size (bigger, smaller) is the diameter of the hoof. Toe/foot length (short, long) is what it says, how long (top to bottom) it is.
I'm working on him
And again file upload does not work :( Anyway the book is Principles of Conformation Analysis by Deb Bennett or another is The Horse Structure and Movement by R.H. Smythe
Necro'ing this thread to inquire hopefully if there have been any developments on the project to convert existing Daz Horse 2 materials.
Hi paulawp (marahzen), yes they are still on my project list. But unfortunately have been dropping down in priority for a while now.
Tbh there are no plans to resume work on the project at the moment, though I will take note of your request and move them further up my priority list again.
I was in the finishing stage of converting the UV from Horse 2 to 3 when I lost motivation for the project.
My apologies that this one didn't move through to completion as planned.
No problem! We product users are grateful for cool products to buy (at least I am), and I know there must be all kinds of things that are a factor when it comes to what gets made and when. It would just be great to have all of those already-existing textures available to use in addition to the new ones that were made for DH3.
I'm interested too! I'm always so happy when I can keep on using good stuff that I already own. Sooo maybe notch the project a tiny little bit more back up in priority? I'm sure there must be more interested!
Yep, I own a lot of DAZ Horse 2 also. I will be there to buy it when you are ready to sell.
Hey so I just decided to bite the bullet and pick up the new horse to see if it really was as bad as my first impression.
What has brought me here right now though is a problem I have spotted with the includes poses and I was wondering if anyone else has had this or if its just me.
I am getting odd and bad distortions on te joints when bent, I have just used the laying down pose here to show you but it was happening on most of the included poses.
However the poses from the Free Spirit pack seem to be fine
It almost looks as if corrective morphs are being over applied. Possibly a base set and a 'character' morph corrective at the same time. I'm sorry, I don't have Horse3 so can't check for myself.
Regards,
Richard
Loading base Horse 3 and applying a variety of similar poses, I get no distortion. But if I apply the pose you used above from the Thoroughbred Poses folder, I get a similar situation although still not as horrible as what you are seeing. Dialing in the Thoroughbred corrected the bad bends for me. I have quite a few pose packs for the Horse and I do not get any issues at all.
I was using the Thouhabread, but I was getting this with both the horse poses and the thoroughbred ones as well as if I just manually posed the legs
I will investigate this thanks for the idea
Aha, it looks like it's time for my annual necro on this thread to inquire hopefully about the UV project. Hoping that perhaps it found new life at some point? There are a few of us at least who still have our fingers crossed on this.
I remember being told via sales blurb that early adopters (DH3 was pre-sold) would get a consideration on additional hair options. It hasn't turned out. The dForce mane and tail look like James Brown's perm, and that's not just because I'm incompetent, since all the promos look just as bad. The expansion gave more options, but it still looked like before. Harry and DH2 have better-looking hair options, but DH3 requires post-production to even be presentable.
Well, this is more or less what I was expecting to happen when I started this thread 2.5 years ago. To be fair, there IS actually a bit more for H3 than I expected there to be, but it is depressing that there's been so little done overall...especially considering that it's really only been a little over a hundred years snce most of human civilization depended on horsepower for basic everyday needs.
