Camera Magic (Commercial)
123457
  • Xandyr78Xandyr78 Posts: 144
    Hi!
    Would it be possible to create an add-on for this that remembered shaders/materials?  I have a set I built from a product available here, the Create-A-Room product sets.  I LOVE them, but they have a (pretty major) hiccup in that the wall material zone has two parts: top and bottom, but no "front" and "back," meaning I can't use a single wall prop and texture each side of it individually, for say a hallway adjacent to a room, and duplicating the prop/shifting it slightly creates much larger scenes than my system can manage.
    I'd love to be able to position cameras in the hallway that would show one set of shaders/materials for walls that were part of connected rooms, then place cameras within the rooms that showed the inner shaders/materials correctly.
    I'm not sure if I'm explainign this well, so if clarification is needed, let me know.
  • Zev0Zev0 Posts: 7,122
    Hi. There isn't enough demand for a materials\shader add-on unfortunately to warrant it's development time. If this situation changes we will re-review.
    Understandable.  Disappointing, but understandable.  Thanks for taking the time to respond!
  • emerazeaemerazea Posts: 2
    edited January 2024
    My goal is to use Camera Magic + the Pose add-on to help me store lots of variations of character reactions + clothing in a single DAZ file so that I can generate sceneless reaction poses.
    This *mostly* seems to be going well. I've got the following experimental set up of groups + cameras:
    • Emotions (Adjust character poses)
      • Emotion - Zero
      • Emotion - Happy
    • Clothing (Adjust visibility of wearables)
      • Clothing - Zero
      • Clothing - Casual
      • Clothing - Party
    The behavior of the script seems to be that I can choose one Pose camera, then one Visibility camera, and end up with a combination of the two... which is *excellent*. It seems like I could theoretically use one of the render queue plugins to help automate my way through getting the poses I need in a *consistent* way. (And if I change a character's nose or something, I wouldn't have to *manually* redo 100s of files).
    Issue 1: Heels
    However, several outfits use different heels, and therefore need additional slight pose modifications (definitely to the feet, and also to the character's y coordinate).
    I attempted to add a "Foot Pose - Party" camera to the list, and was hoping that in the "What would you like to save Pose data for?" dialog, I could choose "Selected Assets" while selecting the "Left Foot" and "Right Foot" bones. However, this saves the character's entire pose to my "Foot Pose - Party" camera.
    I suppose "Selected Assets" means it's grabbing the entire figure? If so, would it be simple to add a "Selected Bones" option? Would that even get me where I need to be?
    Issue 2: All visibility settings are saved in a visibility camera
    The screen shots in the store are a bit misleading in that I misread the helpful red/green diagrams as being actual in-DAZ UI elements. I was imagining being able to selectively choose *which* visibilities to apply to a camera.
    The current behavior leads to two small annoyances:
    1. If I add new clothing items to the character (even if I toggle their visibility off by default), all of the cameras assume their visibility should be on by default. This... would mean updating every Visibility camera I have each time I add more clothing items. Not a dealbreaker.
    2. I won't be able to add a camera that selectively turns lights on or off for the other cameras to use. This could have been cool to generate the same poses with nightclub vs daylight lighting. But... this... is where I'm pretty sure I'm trying to use this tool way out of its intended use-case. Hammer/nail.
    Are there better ways to handle what I'm trying to do? This entire plugin feels like a bit of an imaginative way to circumvent some of DAZ's most glaring flaws, so I'm not really sure how much of what I'm trying to accomplish with it is *too* outside of the box versus being *exactly* the kind of trickery that could make DAZ-life easier.
    Post edited by emerazea on
    edited January 2024
    "I suppose "Selected Assets" means it's grabbing the entire figure? If so, would it be simple to add a "Selected Bones" option? Would that even get me where I need to be?"
    Selective bones would seriously slow down the script between switching cameras.
    1. Unfortunately this is how the script works in order to do what it does.
    2. Not possible unfortunately.
    "Are there better ways to handle what I'm trying to do?"
    No Idea to be honest. Sounds like you have a handle on things.
    Post edited by Zev0 on
  • DamselDamsel Posts: 391
    Thistle said:
    Does anyone know if Camera Magic works with (is compatible with) ManFriday's Render Queue ? Render Queue | Daz 3D
    I have been using that for my automatic render workflow and am very happy with it.
    So Render Queue rendering all the different camera's of a file while Camera Magic orchestrates what is in the actual picture.
    That would make these two products very strong companions !
    How did you get it to install? When I tried to install it, my antivirus screamed in rage and shoved it into quarantine, swearing it was a virus. I tried several times, and it ate it every time.
    Anyway, I bought this today and noticed something weird. The zip says it's for Daz Studio Public Build. When I tried to install it with DIM, Dim doesn't seem to see it. :/
  • ElorElor Posts: 3,229
    edited February 2024
    It's strange, because it (and its two addons) does appear in DIM when I'm typing Camera in the search bar:
    It's already installed on the screenshot, but for contents bought on Daz Store, I'm only using DIM.
    1400 x 640 - 164K
    Post edited by Elor on
  • RobertDyRobertDy Posts: 272
    edited July 2024
    I'm having a problem. When in one of the magic cameras, say I do a hair blow morph, then I switch to the Perspective View camera and tweak other things, then I return to the magic camera, but the dialed hair blow morph is gone. Please tell me how to fix this cos it's really going to affect whether I can continue using this product. I need to switch to the Perpsective view every now and then to make adjustments. EDIT this also happens when a switch to another magic camera when i apply the hair blow morphs from the previous magic camera.
    Post edited by RobertDy on
    Hi. What hair set is this....Also what setting did you ask the camera to remember?
    Liv hair by outoftouch, but I don't think it matters? I asked Camera Magic and Camera Magic Plus to rememebr visibility data and shaping data. I have two cameras that have the characters wearing different clothes and having different body shapes, so naturally I'd want changes to the hair morph to be reflected in both cameras, and not disappearing when I switch cameras.
    edited July 2024
    Works fine here. Be sure to select All rigged assets....
    edited July 2024
    Nope, still not working. With clothes and shaping combination set 1, I save visibility date and shaping data (all rigged assets) to Camera 1, and clothes and shaping combination 2 is saved to Camera 2. I dial a hair morph either in Perspective View, Camera 1 or Camera 2, and the moment I switch to another Camera, the morph is dialed back to zero.
    Edit: to clarify, with Camera 1, I enable visibilty data saving in Camera Magic, then I go to Camera Magic Plus and save visibility and shaping data (all rigged models) to Camera 1. Then with a different clothing and shaping set, I repeat under Camera 2.
    edited July 2024
    "I dial a hair morph either in Perspective View"
    This needs to be done on the desired camera...perspective view will not hold any data.
    If you have Plus you dont need to use the standard Camera Magic anymore. The visibility/enable options are there in Plus. I don't know why it is not working for you. Send me a log file please. Under script settings/options there is a get log function.
  • One question I have is around how much this makes save file size grow. With 5 characters my save files are already pushing 140MB (environment only takes 10MB of that) so I'm hoping I could do multiple renders in the same environment without seeing too much growth in that. Does each camera only persist the difference data or is it persisting the entire character?
    Hi. Camera Magic only adds camera data.. Between a scene with and without Camera Magic it was only 72kb difference. Very Tiny.
  • I see there is a bundle in the store, anything new\updated? Or is it just the bundle which is new?
    edited August 2024
    There was an update that went live recently that adds the ability to remember hdri environment settings eg rotation and position etc. for the Pose Addon.
  • crosswindcrosswind Posts: 9,580
    edited August 2024
    An issue in here, maybe just for me.... With ver. 1.3, if I'm with perspective view, I have no way to see the menu when I click CMP button on the toolbar other than that warning message (I know what it is for...). But actually now I just want to Disable Camera Magic before switching to a certain Camera 'cause the target Camera might be with wrong setting of visibility / poses / morphs... It used to be almost one of my frequently-used actions, but now I cannt do it ! I have to switch to an unwanted Camera firstly, Disable CMP, then switch to the target Camera, it is troublesome ~~
    @Zev0 Can you modify the code to at least let users see the Disable / Enable menu items in such a case, or even tweak to something more convenient ?  Now, I have to put both CM and CMP scripts as Action buttons onto the toolbar ~~
    Post edited by crosswind on
    edited August 2024
    Hi. In CMP, simply make a new dummy camera, go to it and then then disable/enable camera magic from there. I will see about doing an update.
    edited August 2024
    Thank you! Neat idea! Why didn't I think of that... Anyway, two versions works for me now but still I expect an update. Thanks!
  • I have an issue with saving a geograft inside a geograft that keeps dropping the morphs when using your script.
    It's Full Monty BBQ and I grafted it and fixed the morphs to adhere to the custom character. But when I use your script, the next time I open the scene, the morphs are gone and/or regenerated instead of loading the morphs I saved to the graft. They are listed inside the .duf as shapes, but they don't load or save properly. The files are saved to a proper path inside my data section, so they should load, just like the main geograft Futalicious does.
    So, is it an issue with my settings, or does the script not like secondary grafts or something?
  • nonesuch00nonesuch00 Posts: 18,748
    IThis looks pretty useful for something I'm working on now. I will buy it, thanks for your work.
    If you rigged a geo-graft onto another geo-graft, you would have to select both of the geo-graft nodes before capturing shape data for a camera...
    Sorry that I replied so late to this, as I decided to temporarily stop using this product only until recently. Recap - Camera Magic doesn't save any morphs dialed into my hair products. I dial a morph for a hair that I use in either Perspective View or any Camera that has Camera Magic enabled, but the moment I switch to another camera, the dialed morph is lost. You requested me to get a log, but when I click on the get log option in Camera Magic, it says "Unable to find Script Runs in log."
    edited February 20
    Hi. you can send a log from within studio itself under help troubleshooting..But please clear log before you use camera magic or there will be endless lines of entries to go through..Thanks
    What hair set is this?
  • xyer0xyer0 Posts: 6,338
    edited February 24
    I save BOTH the Pose AND the Shape settings in Camera Magic Plus for hairs (mostly using OOT & AprilYSH), and that has solved my issues.
    Also, it is not enough to dial a morph, you must also save the Camera Magic Plus settings on the desired camera with the morph dialed in to retain them.
    Post edited by xyer0 on
    Is there a way to deactivate appearance of the dialog box when loading a scene that uses Camera Magic? ("Do you want to turn the magic on?")
  • souji_monarusouji_monaru Posts: 57
    Just to let anyone know, the problem I was having is the morphs I made for the figures in my scene didn't have the right paths for parent (they just inked back to the subset file), so I just needed to fix the target parent and now it works. Good to know there's nothing wrong with the Camera Magic! :P
