Midnight Bones for Genesis 9 doesn't accept standard hand poses
Midnight Bones for Genesis 9 will not accept standard hand poses (see example screen-shot). This is how it responds to a simple Grasp pose.
Has anyone figured out how make the product function correctly?
  • crosswindcrosswind Posts: 10,324
    I saw no issue with the official Grasp pose control on the selected hand... To be exact, what pose control property did you use ?
    2560 x 1392 - 618K
  • CA415CA415 Posts: 167
    Thanks for the quick reply.
    You have to add a new geometry shell to the skeleton figure using "MB fitted with Genesis 9" to see that the skeleton does not conform to the Genesis 9 figure as promised.
    Sorry, I forgot to attach the screen-shot showing the standard Genesis 9 hand grasp control dial.
    2024-07-07 17_05_57-DAZ Studio 4.22 Pro - !!!-Empty-2024-Medium Figure-Figure Height-1.duf.png
    635 x 778 - 182K
    edited July 2024
    Okay, I got what you meant. You were checking and comparing the pose. Yes, after testing, it's an issue of wrong rigging... You may fill a ticket.
    Then if we want to fix it, we can rerig it ~
    - export standalone MB Skeleton to OBJ with Base Resolution and import OBJ. Rig it to G9 with Transfer Utility.
    - transfer all morph properties / corrective morphs from MB Skeleton to MB Rerigged with Transfer Utility
    - activate Geometry Editor, select All surface of G9, Set AutoHide Faces for Attachment > select MB Rerigged.
    - convert MB Rerigged to SubD and apply a Material Preset to it.
    Done ~ The result will be correct. Then save G9 as a Subset, or a Figure Asset with your Vendor Name.
    2560 x 1392 - 1M
    2560 x 1392 - 605K
    Post edited by crosswind on
    Thanks, again, for your help.
    I've submitted a ticket.
