This script to play a sound when finished rendering not working anymore?
James
Code removed
This is not my script, I tried once, it works, but now it doesn't.
I put the script and the sound file on the scripts folder.
Can anyone figure out why it doesn't play the sound anymore?
When you tried this script for the first time, where did you place the dsa file ? in Render Settings - Post Process Script ?
I forgot
If so, just firstly try placing the script into Render Settings - Post Process Script, where it should be there as per my understanding.
not working.
That will re-render again after a render is finished.
Ah, it requires me to stay at daz window.
Hemm... a bit beats the purpose of having an alarm.
Oh... may bad, my dizzy eyes... there's a line of code of DoRender() !
So, you should just directly run this script.
Is there a way to make it play the sound without having to stay at daz?
If it isn't your script then yoou shouldn't post it without permission.
A script should work without tDS being the application with focus, as far as I know.
But it doesn't play the sound, if for example I were browsing the web.
