This script to play a sound when finished rendering not working anymore?
JamesJames Posts: 1,189
edited July 2024 in Daz Studio Discussion
Code removed
This is not my script, I tried once, it works, but now it doesn't.
I put the script and the sound file on the scripts folder.
Can anyone figure out why it doesn't play the sound anymore?
  • crosswindcrosswind Posts: 10,249
    When you tried this script for the first time, where did you place the dsa file ? in Render Settings - Post Process Script ?
  • JamesJames Posts: 1,189
    I forgot
    If so, just firstly try placing the script into Render Settings - Post Process Script, where it should be there as per my understanding.
    edited July 2024
    not working.
    That will re-render again after a render is finished.
    Ah, it requires me to stay at daz window.
    Hemm... a bit beats the purpose of having an alarm.
    Post edited by James on
    edited July 2024
    Oh... may bad, my dizzy eyes... there's a line of code of DoRender() !
    So, you should just directly run this script.
    Post edited by crosswind on
    James said:
    not working.
    Oh,faint...
    Is there a way to make it play the sound without having to stay at daz?
    I'm afraid only a plugin can do...
  • Richard HaseltineRichard Haseltine Posts: 111,348
    If it isn't your script then yoou shouldn't post it without permission.
    A script should work without tDS being the application with focus, as far as I know.
    But it doesn't play the sound, if for example I were browsing the web.
