Where is the Decimator Plug-in?
I purchased the decimator plug-in with DIM and it is nowhere to be found in Daz Studio 4.22.  It is not in the Window-Panes bar where it should be.  what the heck is going on???
  • barbultbarbult Posts: 27,583
    You can't purchase a plugin with DIM. I assume you meant you installed it with DIM. Check in Help/About Installed Plugins. Is Decimator listed there? Does it have a green plug? Has your Decimator Serial Number been entered?
  • GordigGordig Posts: 10,810
    You purchased it with DIM, or you installed it with DIM? Check Help -> About Installed Plugins to see if it's there, and if it needs to be activated.
  • neomanneoman Posts: 85
    Yes... INSTALLED it with DIM.  Sorry.
    Thanks, that was it.  Just needed to insert the serial number.  Thanks again!
    A quick fix is always good! yes
