Show us your Daz AI Studio Images
1121315171827
  • ArtiniArtini Posts: 10,364
    edited June 2024
    And another two figures fight...
    1024 x 1024 - 406K
    Post edited by Artini on
    edited June 2024
    Battle scene...
    1024 x 1024 - 366K
  • felisfelis Posts: 5,943
    Artini said:
    Battle scene...
    But that is 2 evils batling each other....
    The only one, that looked decent...
  • inquireinquire Posts: 2,436
    edited June 2024
    @Artini: What prompts did you use for the two boxers fighting images, if I may ask?
    Closer yet would be wrestlers grappling. How well does that work? I'm not getting the results I'd like, but I must admit I'm still only trying it for free.
    Post edited by inquire on
    edited June 2024
    I wrote wrestling, but it doesn't look so to me.
    1024 x 1024 - 1M
    Post edited by felis on
    edited June 2024
    I have used prompt:
    boxing, two fighters, ring arena
    and I am also using a free version.
    edited June 2024
    Just tried it again.
    One got different results all the time (unless you are using the same seed)
    1024 x 1024 - 440K
    edited June 2024
    Try to use different martial arts names...
    1024 x 1024 - 449K
    edited June 2024
    As long as they use gloves, the image look ok.
    1024 x 1024 - 452K
    edited June 2024
    And one more...
    1024 x 1024 - 404K
    edited June 2024
    The tricky ones are like that...
    1024 x 1024 - 413K
  • FSMCDesignsFSMCDesigns Posts: 12,846
    edited June 2024
    I was going thru some photos in a box and founf some of my cat when he was a kitten (black Himalayan), so wanted to see what DAZ AI would give me.
    2304 x 1792 - 5M
    2304 x 1792 - 5M
    2304 x 1792 - 6M
    Post edited by FSMCDesigns on
    edited June 2024
    Tried some dance poses.
    Anybody with fingers exposed is tricky to get right.
    1024 x 1024 - 431K
  • FirstBastionFirstBastion Posts: 8,049
    edited June 2024
    Trading Sabers
    @Artini: Thanks for all the help. What does "seed" mean?
  • StingerStinger Posts: 324
    edited June 2024
    Early Halloween generation
    1024 x 1024 - 1M
    Post edited by Stinger on
    Seed means that you use an image to base/influence your next generations off of. With DAZ AI studio, if you get an image that is almost what you want, you can seed it, then change the prompt influence and regenerate and it will create a new image based off the seed and it will be slightly different from the original.
    edited June 2024
    If you scroll down on the left side of the web page with Daz AI Studio,
    then you will see the field with the Seed value, by default it is empty.
    If you want to see the Seed value for the generated image hover mouse pointer over it
    and click on the icon pointed by my red arrow.
    Then you will get the Seed for this image.
    900 x 380 - 79K
    edited June 2024
    There are some other kind of seeds here...
    1024 x 1024 - 387K
    edited June 2024
    Nice rural environment...
    1024 x 1024 - 607K
    Continuing on the seeds discussion,  you can try an experiment. Type the single word "seeds"  and see what you get.
    Then generate another set of images using the number 123456789 in the seed field while keeping the word SEEDS in the prompt.
    1594 x 808 - 285K
    Do I have to type the prompt that I want to seed into the seed box? If I want to use as a seed the most recently generated image do I just click the seed box and that's it? But then I can alter the prompt slightly? Is that the technique to use? I'm really not sure. How does one influence the seed prompt?
  • Richard HaseltineRichard Haseltine Posts: 108,595
    The seed is a number, it is used to generate the initial noise pattern that the algorithm then modifies based on the prompt. If you have the same seed and prompt then you should get exactly the same image - the process is deterministic. If you use the same seed and adjust the prompt a bit then you should get a variant on the initial result.
    The main way to influence the seed prompt is to just change the Prompt Strictness from where it was. You can also change the actual prompt also. One thing I have found, with the Prompt Strictness, at 100% things will be more accurate, but with less detail. At 0%, you get less accuracy, but more detail.
    edited June 2024
    Testing minimalistic prompts with just one word, like:
    Snowboarding
    and my secret seed number...
    1024 x 1024 - 420K
    edited June 2024
    Another simple prompt:
    Ketchup
    Also testing how Daz AI Studio handle text labels.
    1024 x 1024 - 379K
    edited June 2024
    Another good one:
    Furries
    1024 x 1024 - 425K
    edited June 2024
    I also like this prompt:
    Kangaroo
    1024 x 1024 - 411K
    edited June 2024
    Unexpected visit made from prompt:
    Skunks
    1024 x 1024 - 449K
